Audi S6 TDI (F2) 2023: Specs & Review
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Dieselschrauber Bar
Into
Post13-01-2026, 9:13    Subject: Audi S6 TDI (F2) 2023: Specs & Review Quote
Good day.
I would like to reset the service indicator, but unfortunately, it's not working.
"The message 'No label file available for this control unit' is displayed."
4K0 920 790 G
Perhaps someone has a solution, thank you.
Best regards, Toni.
Translated on 26-07-2026, 15:14.
Post13-01-2026, 10:05    Subject: Audi S6 TDI (F2) 2023: Specs & Review Quote
A current vehicle scan is required for the car:
If the currently
available
VCDS version does not recognize the specific control unit:
/viewtopic.php?t=28268}
Translated on 26-07-2026, 15:16.
Post22-01-2026, 19:07    Subject: Audi S6 TDI (F2) 2023: Specs & Review Quote
Did you manage to create the files?
These are necessary to improve the support for the respective control units by the manufacturer.
Translated on 26-07-2026, 15:17.
dieselschrauber likes this.
Post23-01-2026, 8:20    Subject: Audi S6 TDI (F2) 2023: Specs & Review Quote
Hi there,
If your vehicle model doesn't have the SFD (Vehicle Diagnostics Protection) function blocked, you can also reset the service interval indicator step by step. In my Golf 7 (as mentioned in my profile), I had to manually reset it myself because there was no corresponding label file available in VCDS.
To do this, certain adaptation channels within the STG 17 control panel must be overwritten. If you are not sure which ones these are, it is best to provide an image of the STG 17 as a CSV file here. This can then be read, converted into a more readable Excel file, and the channels can be identified.
What you also need are the applicable service intervals. Do you have the RLF (Reparatur-, Leistungs- und Funktionsprüfung) document titled "Maintenance in Detail" for your model?
Translated on 26-07-2026, 15:18.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS HEX-V2 for Audi Q4 2023 On-Board Diagnostics (OBD)
No new posts Audi S6 Diesel 3.0 344 HP, Type F2, Year 2023, SRI Dieselschrauber Bar
No new posts Touran 2023: Reset Service Interval On-Board Diagnostics (OBD)
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
