VCDS on Linux/Mac: Installation & Setup
Post26-11-2023, 13:49    Subject: VCDS on Linux/Mac: Installation & Setup Quote
VCDS can be used on a virtual machine with Windows, and also under other operating systems.
For example, Apple's macOS or Linux.
Currently, VirtualBox runs on Windows, Linux, macOS, and Solaris hosts and supports a large number of guest operating systems including but not limited to Windows (NT 4.0, 2000, XP, Server 2003, Vista, 7, 8, Windows 10 and Windows 11), DOS/Windows 3.x, Linux (2.4, 2.6, 3.x, 4.x, 5.x and 6.x), Solaris and OpenSolaris, OS/2, OpenBSD, NetBSD and FreeBSD.
https://www.virtualbox.org/ An important prerequisite is that VCDS device drivers must be available for the computer's CPU.
HEX-V2 and HEX-NET support x86, AMD64, and ARM as processor platforms.
My development machine, for example, uses Ubuntu 22.04 LTS with VirtualBox and Windows 8.1 as a virtual machine.
To use the USB device (e.g., HEX-V2 / HEX-NET) within the virtual machine, you need to make the corresponding USB device available to the virtual machine. This essentially means that the host operating system (in my case, Ubuntu) is no longer responsible for the device; instead, the virtual machine takes over control.
Under Linux, the `dmesg` command (run as root) provides information about connected USB devices, among other things.
The easiest way is to bind the VirtualBox USB filter generously to the USB product string (a restart of the virtual machine may be necessary).
Now I can use VCDS as usual, in my case on Ubuntu.
 VCDS mit VirtualBox unter Windows auf Linux Host
 File size:  132.31 KB
 Viewed:  4079 times
 VCDS USB Product String
 File size:  626.83 KB
 Viewed:  4057 times
 VCDS unter Linux
 File size:  321.63 KB
 Viewed:  4500 times
Translated on 28-07-2026, 3:57.
Post14-01-2026, 20:38    Subject: VCDS on Linux/Mac: Installation & Setup Quote
Alternatively, QEMU can also be used with the Virtual Machine Manager.
I am currently using Kubuntu 24.04, and I found it easier to set up and use.
Complete package list for QEMU and Virtual Machine Manager under Ubuntu 24.04
1. Basic installation (Essential)
Code:
sudo apt update
sudo apt install qemu-kvm libvirt-daemon-system libvirt-clients virt-manager -y
Included packages:
  • qemu-kvm - QEMU with KVM support (hardware virtualization).
  • libvirt-daemon-system - Libvirt daemon for VM management.
  • libvirt-clients - Command-line tools for Libvirt.
  • virt-manager - A GUI for VM management (Virtual Machine Manager).
2. Network & Bridge (optional, but recommended)
Code:
sudo apt install bridge-utils net-tools dnsmasq dnsmasq-base -y
# ODER für virtio-net Unterstützung
sudo apt install virtio-net-drivers -y
3. UEFI/EFI Support (for modern VMs)
Code:
sudo apt install ovmf qemu-efi-aarch64 qemu-efi -y
4. Additional QEMU Utilities
Code:
sudo apt install qemu-utils libguestfs-tools -y
5. Performance Optimization
Code:
sudo apt install cpu-checker qemu-system-x86 qemu-system-gui -y
6. Complete installation line (all-in-one)
Code:
sudo apt update && sudo apt install \
  qemu-kvm \
  libvirt-daemon-system \
  libvirt-clients \
  virt-manager \
  bridge-utils \
  ovmf \
  qemu-utils \
  libguestfs-tools \
  cpu-checker \
  qemu-system-x86 \
  qemu-system-gui \
  virtio-net-drivers \
  -y
7. After the installation
A. Add users to groups
Code:
sudo usermod -aG libvirt $USER
sudo usermod -aG kvm $USER
newgrp libvirt
B. Start services
Code:
sudo systemctl enable --now libvirtd
sudo systemctl start libvirtd
sudo systemctl status libvirtd
C. Check virtualization
Code:
kvm-ok
egrep -c '(vmx|svm)' /proc/cpuinfo
8. Optional packages for specific applications
For Windows guests
Code:
wget https://fedorapeople.org/groups/virt/virtio-win/direct-downloads/stable-virtio/virtio-win.iso
For USB Passthrough
Code:
sudo apt install usbutils -y
For GPU passthrough.
Code:
sudo apt install intel-microcode amd64-microcode -y
9. Verify installation
Code:
which virt-manager
which virsh
which qemu-system-x86_64
virsh list --all
qemu-system-x86_64 --version
10. Firewall rules (if UFW is active)
Code:
sudo ufw allow libvirt
sudo ufw reload
11. Alternative: Minimal installation (command-line interface only)
Code:
sudo apt install qemu-kvm qemu-utils libvirt-clients -y
12. Key dependencies at a glance:
  • qemu-kvm - A KVM hypervisor using QEMU.
  • libvirt-daemon-system - Background service for VM management.
  • virt-manager - Graphical interface.
  • bridge-utils - Network Bridging.
  • ovmf – UEFI firmware for VMs.
  • qemu-utils - Tools for disk images (qemu-img).
  • libguestfs-tools - Tools for accessing virtual machine file systems.
13. Starting virt-manager:
Code:
virt-manager
14. Troubleshooting:
If virt-manager does not start:
Code:
groups | grep libvirt
sudo systemctl restart libvirtd
export LIBVIRT_DEFAULT_URI="qemu:///system"
If the network is not working:
Code:
sudo virsh net-start default
sudo virsh net-autostart default
Translated on 28-07-2026, 4:05.
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS on Linux: Virtualization Works! On-Board Diagnostics (OBD)
No new posts VCDS 26.9.0 Update: SFD Now Available in German Version On-Board Diagnostics (OBD)
No new posts VCDS 11.11.5 is outdated, VCDS: Software is outdated On-Board Diagnostics (OBD)
No new posts VCDS-RKS 12.12.2: Update & Features On-Board Diagnostics (OBD)
