Golf 8: Missing File During Auto Scan (12/2025)
MatthiasMundl
dieselschrauber likes this.
Post28-04-2026, 19:32    Subject: Golf 8: Missing File During Auto Scan (12/2025) Quote
During the car scan, the VCDS software reported that a file could not be found and requested that I submit the car scan log. I have a new Golf 8 eHybrid manufactured in December 2025 – the VIN is included in the log.
Sincerely,
Matthias Mundl
****Start LOG***
Monday, April 27, 2026, 2:22:57 PM: 0.8547
VCDS – a Windows-based VAG/VAS emulator – runs on Windows 8.1 x86.
VCDS version: RKS 25.3.2.0, HEX-V2 CB: 0.4701.5
Data as of: 20260129 DS365.0
http://shop.dieselschrauber.org/en
Dealer/Workshop name: self-entered.
Vehicle Identification Number (VIN): WVWZZZCD1TW412252
License plate number: DRV-OX2026E
Mileage: 455 km
Repair order number: 00001
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag für einen Spaziergang."
Vehicle type: CD-VW38P PA* (5QS)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 36 42 44 51 52 5F 69
6C 75 8C A5 C6 D6 D7 8105 8109 810A 810B 810C 813C C002 C003
Mileage: 455 km
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
05-Access/Startup Report - Status: OK 0000
08-Climate control/heating unit - Status: OK 0000
09-Central Electrical System -- Status: Error 0010.
Parking Assist System 2 -- Status: OK 0000
13-meter distance rule -- Status: OK 0000
15-Airbag -- Status: OK 0000
17-Terminal block module -- Status: Error 0010.
19-pin diagnostic interface -- Status: Error 0010.
23 - Brake force amplifier -- Status: OK 0000
2B steering column lock. -- Status: OK 0000.
36-seat adjustable passenger seat -- Status: OK 0000.
42-Door Electric Driver -- Status: OK 0000
Steering assist - Status: OK 0000.
51-Electric drive -- Status: Error 0010.
52-door electric passenger door - Status: OK 0000.
5F-Information Selection. I -- Status: Error 0010.
69 followers -- Status: OK 0000
6C Rear View Camera -- Status: OK 0000
75-Telematics -- Status: OK 0000
8C High-Voltage Battery Management System -- Status: OK 0000
A5 Front/Forward-facing camera -- Status: OK 0000
C6 battery charger -- Status: Error 0010.
D6-Left lighting control 2 -- Status: OK 0000
D7-Light control right 2 -- Status: OK 0000
8105-DC/DC Converter 12V -- Status: Error 0010
8109 - Short-range radar 1 -- Status: Operational.
810A Short-Range Radar 2 -- Status: Operational.
810B Short-Range Radar 3 -- Status: Error 0010.
810C Short-Range Radar 4 -- Status: Error 0010.
813C Charging Communication 1 -- Status: OK 0000
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine Control Module (J623-DUCB)
File label: Redirection failed!
Part number SW: 05E 906 019 CG, HW: 05E 907 309 CC.
Part number: 1.5L TSI HY H80 4820.
Revision: KLH80000 CVN: FD656EBFC45B7E91
Encoding: 011D00326474050830080000001000000000000000000000
Operating number: WSC 01357 011 00200
ASAM Dataset: EV_ECM15TFS01105E906019CG 003007
ROD: EV_ECM15TFS01105E906019B.rod
VCID: 6D831FAB1D13E852555-8038-R SFD+SFD2
VINID: 9E69EAAAA4D40649C404208508A157763E
Active oil separation system:
No error codes found.
Readiness: 0000 0000
Address 02: Transmission (J743)
Label file: DRV&BH-927-711.clb
Part number SW: 0DD 906 556 FQ, HW: 0DD 300 048 B.
Component: GSG DQ400 H06 0860
Serial number: VTH02510290417 CVN: F16B162B
ASAM Dataset: EV_TCMDQ400024 001012
ROD: EV_TCMDQ400024.rod
VCID: 0E41782770D5734A0CF-805A-R SFD
Park closure:
Subsystem 1 - Part number SW: 5WA 907 484 A, HW: 5WA 907 484.
Component: ZSB_SB_AUTO H03 1092
Serial number: 00000000000094961555
Selector lever:
Subsystem 2 - Part number SW: 5H0 713 059 S, HW: 5H0 713 059 S.
Component: ZSB_SB_Mono H03 0014
Serial number: 92478YK700061
Address 03: Brake Electronics (J104)
Label file: None.
Part number SW: 5WA 614 517 DT, HW: 5WA 614 517 BT.
Component: ESC H32 0337
Serial number: 63155000001853. Data version number: V03935479EL 0001. CVN: D286145A4B4898CD.
Encoding: 2C185428A4CD39BC410355AC9EB701C93ACF952151A000
ASAM Dataset: EV_Brake1ESCMQB37WUNECE 006026
ROD: EV_Brake1ESCMQB37WUNECE_004.rod
VCID: 1D630F6BAD33D8D2855-8048-R SFD+SFD2
Address 05: Access/Startup Authorization (J518)
Label file: 5WA-959-436.clb
Part number SW: 5WA 959 436 AC, HW: 5WA 959 436 M.
Component: Kessy IOBOX 122 0771
Serial number: --------------- Data version number: V03935428XR 0001
ASAM Dataset: EV_Kessy37w 005030
FILE: EV_Kessy37w.rod
VCID: 1573174B550380924D5-8040-R
Address 08: Climate Control/Heating Module (J979)
Label file: Bypass failure!
Part number SW: 3WA 907 007 E, HW: 3WA 907 007 A.
Component: Climatronic H01 5089
Serial number: 225062502365560. Data version number: V03935478AH 0001.
Encoding: 002001018010020010100010101011112000132100201001000000000000
ASAM Dataset: EV_ACClimaBHBE3ADV 002062
ROD: not applicable.
VCID: 47CF8D035F2FE2020F9-8012-R SFD+SFD2
Subsystem 1 - Part number SW: 5WA 907 527 A, HW: 5WA 907 527 A.
Component: E857 H01 0103
Serial number: 00001231025194431118
Subsystem 2 - Part number SW: 3WA 816 797 E, HW: 3WA 816 797 E.
Component: J842 eKK H07 0002
Serial number: 3WA816797E11112512QZ
Subsystem 3 - Part number SW: 85E 816 682 L, HW: 85E 816 682 L.
Component: N636 EV1_KaMi H10 0107
Serial number: 00001102052528300474
Subsystem 4 - Part number SW: 4M0 959 603 J, HW: 4M0 959 603 J.
Component: G395 pT-Sensor 1 H20 0020
Subsystem 5 - Part number SW: 3WA 963 231 A, HW: 3WA 963 231 A.
Component: J848 HV-PTC 700 0700
Serial number: DAB00305112500002478.
Subsystem 6 - Part number SW: 11A 907 049, HW: 11A 907 049.
Component: E265 KPH; H02 0183.
Serial number: G08S20.08.2500971612.
No ASAM data available: "EV_ACClimaBHBE3ADV" (VW38).
Address 09: Central Electronics (J519)
Label file: None.
Part number SW: 5WA 937 086 CD, HW: 5WA 937 086 BJ.
Component: BCM37w_M238 0517
Serial number: BXJ53F240925940. Data version number: V03935476BD 0001.
ASAM Dataset: EV_BCMwBL 005001
VCID: 1573174B550380924D5-8040-R SFD+SFD2
Subsystem 1 - Part number SW: 5H1 955 119 B, HW: 5H1 955 119.
Component: FWISCHER_MYJT 003 0061
Serial number: 900K53F0302526900987
Subsystem 2 - Part number SW: 89A 955 555 B, HW: 89A 955 555 B.
Component: G397_RLFSS 004 0007
Serial number: TTZ53506092500012475.
Subsystem 3 - Part number SW: 5H0 941 193 AK, HW: 5H0 941 193 AK.
Component: LiSi H06 0008
Serial number: 92471YJF002DK
Subsystem 4 - Part number SW: 5H0 925 200 R, HW: 5H0 925 200 R.
Component: DiETa H07 0008
Serial number: 92471YKA000C1
Subsystem 5 - Part number SW: 5H0 959 561 CG, HW: 5H0 959 561 CG.
Part number: VW LINDA 505 0835.
Serial number: MW3LND06112500010686
Subsystem 6 - Part number SW: 5Q1 953 507 GA, HW: 5Q1 953 549 F.
Component: J527 SMLS MQB 005 0080.
Serial number: 00000007112504221426
No ASAM data available: "EV_BCMwBL" (VW38).
Address 10: Parking Assist 2 (J446) Label file: None.
Part number SW: 5QS 919 294 B, Hardware: 5QS 919 294.
Component: PDC 08ch low H01 0191.
Serial number: 000004112594560. Data version number: V03935460YB 0001.
Encoding: 1040014111
ASAM Dataset: EV_EPHBO18VW3360000 001010
VCID: 5DE34F6BEDB398D2C55-8008-R
No ASAM data available: "EV_EPHBO18VW3360000" (VW38).
Two error codes found:
1114113 - ROD - Unknown error code.
- 00 [00101100]
Occasionally - confirmed - checked since last deletion.
Environmental conditions:
Error priority: 6
Error frequency: 1.
Lost Count: 18
Date: 2026.04.20
Time: 18:40:05
13640960 - ROD - Unknown error code.
- 00 [00101000]
Error priority: 6
Error frequency: 6.
Lost Count: 8
Mileage: 293 km
Date: 2026.04.18
Time: 17:27:35
Address 13: Distance Control (J428)
Label file: * None
Part number SW: 1N3 907 567 E. Hardware: 1N3 907 819 A.
Part number: ACC Bosch MQB H03 0550.
Data version number: V03935474BA 0001.
Encoding: 2D8920EF4071C04040020000000040C0010020008004000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW412 002017
ROD: EV_FRONT_RADAR_BOSCH_VW412.rod
VCID: 392BFBFB19DB84F289D-806C-R SFD+SFD2
3 error codes found:
0322 - Data bus: Implausible message.
U1122 00 [00101000] - -
[FAULT_SWA_MODE_SYSTEM_NOT_AVAILABLE]
Error priority: 6
Error frequency: 9
Lost Count: 39
Mileage: 11 km
Date: 2026.04.07
Time: 9:28:43 PM
Outside temperature: 17.00 °C
Control unit temperature: 14 °C
Voltage at terminal 30: 12.1 V.
Vehicle speed: -0.00 m/s
Longitudinal acceleration: -0.00 m/s².
Adaptive cruise control: Status: initialized.
Mileage: 11 km
text
Monitoring_debug_information: 00 00 00 00 00 00 00 00
text
Event_Id: 02 36
0517 - Data bus: implausible message.
U1122 00 [00101110] - -
[FAULT_KLR_01_CRC]
Error priority: 3
Error frequency: 36
Lost Count: 40
Mileage: 11 km
Date: 2000.00.00
Time: 00:00:00
Outside temperature: 77.50 °C
Control unit temperature: 13 °C
Voltage at terminal 30: 12.6 V.
Adaptive cruise control: Status: off.
Mileage: 11 km
text
Event_Id: 00BA
1416 - Data bus: Implausible message.
[FAULT_VMM_INCONSISTENCY_AWV_PCF]
Error priority: 6
Error frequency: 2.
Lost Count: 38
Mileage: 218 km
Date: 2026.04.16
Time: 15:01:33
Outside temperature: 18.00 °C
Control unit temperature: 21 °C
Mileage: 218 km
text
text
Event_Id: 02 55
Address 15: Airbag (J234) Label file: |5QS-959-655.clb|
Part number SW: 5QS 959 655 Q, Hardware: 5QS 959 655 Q.
Part number: Airbag VW50 010 0250.
Serial number: 000000003C0TPRE Data version number: V03935459VH 0001
Encoding: 88CC008000F0C000000000200000000051540000A1540000C000F680C01300A7
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_AirbaVW50SMEVW49X 001062
ROD: EV_AirbaVW50SMEVW49X.rod
VCID: 71BB03DB012B0CB271D-8024-R SFD+SFD2
Seat belt pretensioner, left side.
Subsystem 1 - Part number SW: 85E 980 945 E, HW: 85E 980 945 E.
Component: BeltPretRevFL 007 0640
Serial number: 18112500170888000000
Seat belt pretensioner, right side.
Subsystem 2 - Part number SW: 85E 980 946 E, HW: 85E 980 946 E.
Component: BeltPretRevFR 007 0640
Serial number: 19112500160408000000
Crash sensor for driver-side side airbag:
Subsystem 3 - Part number: SW: ----------- HW: 480 001 80A 19
Component: SideSensor_Df 001 0887
Serial number: 35700006A78952628240.
Crash sensor for side airbag, passenger side.
Subsystem 4 - Part number: SW: ----------- HW: 480 001 80A 19
Component: SideSensor_Pf 001 0887
Serial number: 35800006A78D526B4C60
Rear side airbag crash sensor (driver's side).
Subsystem 5 - Part number: SW: ----------- HW: 480 050 F0B 19
Component: SideSensor_Dr 000 0149
Serial number: 3510000BCEA4C78AA410
Rear side airbag crash sensor, passenger side.
Subsystem 6 - Part number: SW: ----------- HW: 480 050 E0B 19
Component: SideSensor_Pr 000 0149
Serial number: 3520000C4EA4C410EB40.
Front airbag crash sensor (driver side):
Subsystem 7 - Part number: SW: ----------- HW: 480 050 70B 19
Component: FrontSensor_D 000 014A
Serial number: 3550000BEEA4C409C950
Address 17: Terminal block module (J285)
Label file: | DRV5H0-920-KOM-V1.clb-SRI2
Part number SW: 5H0 920 340 F, Part number HW: 5H0 920 340 F.
Part: COMBINATION INSTRUMENT 501 3365
Data version number: V03935467KE 0001
Encoding: 04240040638C00080180620B2100080800B07C0800
ASAM Dataset: EV_DashBoardVDDMQB37W 006052
ROD: EV_DashBoardVDDMQB37W_006_VW38.rod
VCID: 2513278B85631012DD5-8070-R SFD
"One error found:"
8667138 - Distance.
U197A 00 [00001000] - Data validation.
[Route plausibility check is faulty].
Error priority: 4.
Error frequency: 4
Lost Count: 45
Mileage: 12 km
Date: 2026.04.14
Time: 11:27:44
Address 19: Diagnostic interface (J533)
Label file: * None
Part number SW: 5QS 907 530 J, Hardware part number: 5QS 907 530.
Part number: GW MQB 23 005 3096.
Serial number: SMERBG171125009. Data version number: V03935478QH 0001.
Encoding: 0000000000000000000000000000000
GVL: 3D0000000228D09C80408042C818804004004000007A00000000000000000044
ASAM Dataset: EV_GatewMQBwBL 001027
ROD: EV_GatewMQBwBL_VW41.rod
VCID: 5BE74173F3A796E2BB1-800E SFD+SFD2
Battery monitoring control unit:
Subsystem 1 - Part number SW: 5WA 915 181 H, HW: 5WA 915 181 H.
Component: J367-BDM Hella H01 2362
Serial number: 1123887206
Control unit for multifunction steering wheel:
Subsystem 2 - Part number SW: 571 959 442 C, HW: 571 959 442 C.
Component: E221__MFL-8TH H07 0130
Serial number: 8TH-0070079198250109
Control unit for steering wheel touch detection.
Subsystem 3 - Part number SW: 5H0 959 542 AB, HW: 5H0 959 542 AB.
Component: KLR_JSS_1Zone 089 0023
Serial number: 3136188AA25302164102.
5 error codes found:
8516869 - External charging infrastructure.
P1DCB 00 [01101100] - No charging readiness, Charging container A.
[HVLM_unknown_cp_communication_a]
Error priority: 6
Error frequency: 1.
Lost Count: 35
Mileage: 54 km
Date: 2026.04.15
Time: 14:33:13
8397316 - Low-voltage energy management.
B1C61 F3 [00101000] - Autonomous charging not possible.
[Nvem_autonomous_recharging_not_possible]
Error priority: 6
Error frequency: 1.
Lost Count: 40
Mileage: 455 km
Date: 2026.04.23
Time: 17:01:42
8503302 - Functional limitation due to...
C1249 F6 [00101000] - Mechanical safety functions of the charging management system.
[HVLMSF_error_plug_locking_status_not_locked]
Error priority: 4.
Error frequency: 5
Lost Count: 35
Mileage: 122 km
Date: 2026.04.15
Time: 17:23:50
8516406 - Functionality restriction due to...
Error priority: 4.
Error frequency: 5
Lost Count: 35
Mileage: 122 km
Date: 2026.04.15
Time: 17:23:52
8515686 - Functionality limitation due to...
C1249 F5 [00101110] - Safety functions of the charging management system.
[HVLMSF_leakage_current_error]
Error priority: 4.
Error frequency: 160.
Lost Count: 40
Mileage: 11 km
Date: 2026.04.07
Time: 20:21:58
Address 23: Brake force amplification (J539)
Label file: None.
Part number SW: 5WA 909 059 AH, HW: 3Q0 909 059 C.
Component: EBKV H10 0563
Serial number: BPA085261025013. Data version number: V03935479DT 0001.
Encoding: 1102C5047900000080F7DE7B000049922449922400
ASAM Dataset: EV_BrakeBoostVW37WUNECE 013005
ROD: EV_BrakeBoostVW37WUNECE_013.rod
VCID: 1671104748058B8A44F-8042-R SFD+SFD2
Adresse 2B: Lenksäulenverrieg. (J764) Labeldatei:. DRV3WA-905-861.clb
Part number SW: 3WA 905 861 A, HW: 3WA 905 861.
Component: ELV-MQB_UNECE H05 0071
Serial number: 25000261287014 - Data version number: V03935459HN 0001.
Encoding: 8820000000000000
ASAM Dataset: EV_ELVMarqUNECE 004001
ROD: EV_ELVMarqUNECE_004_VW27.rod
VCID: 49CB8B3B493B147219D-801C-R SFD+SFD2
Address 36: Seat adjustment for driver (J136) Label file: * None
Part number SW: 5QS 959 760 H HW: 5QS 959 760 H
Component: MEM-FS 011 0372
Serial number: 25A1701KA00986. Data version number: V03935451WL 0001.
Encoding: 015892400000B0508803010101010000000000212100000000000000215000
ASAM Dataset: EV_SCMDriveSideCONTIAU736 006013
ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
VCID: 6593678BC5E3D0121D5-8030-R
Address 42: Door Electric Driver (J386) Label file: * None
Part number SW: 3WA 959 593 A, HW: 3WA 959 593.
Component: TSG FS 001 0222
Serial number: Y3007YK300L0B
Data version number: V03935478XZ 0001
Encoding: 003B0720D200008001401030
ASAM Dataset: EV_DCU4DriveSideMAXHKLO 001016
ROD: EV_DCU4DriveSideMAXHKLO_VW41.rod
VCID: 54F5AA4F9E79599A7AB-8000-R SFD+SFD2
Rear door control module, driver's side.
Subsystem 1 - Part number SW: 5Q0 959 408 G, HW: 5Q0 959 164 C, Label file: DRV5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000095533978
Address 44: Steering Assist (J500)
Label file: |DRV5WA-907-14X-V2.clb|
Part number SW: 5QS 907 144 E, HW: 5QS 907 144.
Component: BASGEN1MQB37 104 1122
Serial number: 04860681 Data version number: V03935462UV 0001
Encoding: 00000001000001010001020101000100000001010101
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
ROD: EV_SteerAssistBASGEN1MQB37.rod
VCID: 57EF5D438F8F72829F9-8002-R SFD+SFD2
Address 51: Electric Drive (J841)
Label file: 5QS-907-095.clb
Part number SW: 5QS 907 095 E, HW: 5QS 907 070 C.
Component: LE Gen5 H12 2610
ASAM Dataset: EV_DMCM08800115QS907095E 001001
ROD: EV_DMCM08800115QS907095E.rod
VCID: 5CE5426FF6A991DAB2B-8008-R SFD+SFD2
"One error found:"
42641 - Engine Control Unit (ECU)
U0100 00 [00101110] - No communication.
[Lost communication with ECM/PCM]
Error priority: 2
Error frequency: 72.
Lost Count: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 52: Door electric, passenger side (J387). Label file: * None.
Part number SW: 3WA 959 592 A, HW: 3WA 959 592.
Component: TSG BFS 001 0222
Serial number: Y3007YJM018T5
Data version number: V03935478YB 0001
Encoding: 003B0120DE00008001401030
ASAM Dataset: EV_DCU4PasseSideMAXHKLO 001016
ROD: EV_DCU4PasseSideMAXHKLO_VW41.rod
VCID: 53F7A9539B775EA2631-8006-R SFD+SFD2
Door control module, rear passenger side:
Subsystem 1 - Part number SW: 5Q0 959 407 G, HW: 5Q0 959 163 C, Label file: DRV5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000095384475
Address 5F: Information Selection. I (J794) Label file: | DRV3G5-035-MIB-HGH3.clb
Part number SW: 572 035 816 C. Hardware: 572 035 816.
Component: MU-O-ND-EU H11 2768
Serial number: WG8LGM171125004. Data version number: V03935479BU 0001.
Encoding: 23800006000020000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB37w 002001
ROD: EV_MUOIMQB37w_002_VW49.rod
VCID: 186D1E7F4211BDFA563-804C-R SFD+SFD2
Display and control unit 1 for information electronics:
Subsystem 1 - Part number SW: 14A 919 605 N, HW: 14A 919 605.
Component: ***-E3_13 H50 4047
Serial number: CKS00701112511552739.
Storage devices:
Subsystem 2 - Part number: V03 959 822 LE
Component: EUR 2025/26 3129
Address 69: Trailer (J345) Label file: |DRV5H0-907-383.clb|
Part number SW: 5H2 907 383 E, Part number HW: 5H2 907 383.
Part: Trailer H12 0207
Serial number: 000000000006747. Data version number: V03935440EW 0001.
Encoding: 0100000202001200
ASAM Dataset: EV_TrailFunctG3MPFMHella 001012
ROD: EV_TrailFunctG3MPFMHella_VW27.rod
VCID: 3239CCD7C4AD77AA487-8066-R SFD+SFD2
Address 6C: Rearview camera (J772)
Label file: | DRV5WA-980-556.clb
Part number SW: 5WA 980 556 G, HW: 5WA 980 556 C.
Component: RV eCompact H52 0604
Serial number: FCLK20071025010. Data version number: V03935437YN 0001.
Encoding: 0203C01026140000
ASAM Dataset: EV_CamSysRVCeCFicosBL 003010
ROD: EV_CamSysRVCeCFicosBL_VW41.rod
VCID: 55F3574B958340928D5-8000-R
Address 75: Telematics (J949) Label file: * None
Part number SW: 571 035 284 D. Hardware part number: 571 035 284.
Component: OCUMQBW2023_H H09 0668
Serial number: 0000000508VIXF2 Data version number: V03935483YT 0001
Encoding: 02010601000000210000010013002E07101112111012101110
ASAM Dataset: EV_OCUMWB2023 001072
ROD: EV_OCUMWB2023_VW49.rod
VCID: 176F1D434F0FB2825F9-8042-R SFD+SFD2
"One error found:"
1586 - Invalid dataset.
B2005 00 [01100000] - -
[Ecu_dataset: Download failed due to invalid data record in audio file.]
Occasionally - unconfirmed - checked since last deletion.
Error priority: 3
Error frequency: 1.
Lost Count: 36
Date: 2000.00.00
Time: 00:00:00
Voltage at terminal 30: 12.7 V.
Address 8C: High-voltage battery management (J840)
Label file: DRV3WA-915-184.clb
Part number SW: 3WA 915 184 C, HW: 3WA 915 184 C.
Component: J840 K8C BMC 005 0850
Serial number: 000000301025010
Data version number: V03935425YF 0001
CVN: 331B56E000000000
ASAM Dataset: EV_BMCeVWBSMQB48W 003006
ROD: EV_BMCeVWBSMQB48W.rod
VCID: 4AC9B4374C3D1F6A107-801E-R
Control unit 1 for cell module:
Subsystem 1 - Part number SW: 3WA 915 140 A, HW: 3WA 915 140 A.
Component: SX6 X74 CMC 003 0830
Serial number: 00000029102501010157
Address A5: Front/Forefield Camera (R242) Label file: * None
Part number SW: 3WA 907 217 D, HW: 3WA 907 217.
Component: MFK120_MQB H18 1543
Data version number: V03935474JE 0001
Encoding: 0005000000000000000000BAF840E00500000000206500000000FE00000038FFC3F24074C00000000080000000000000000000000000000000
ASAM Dataset: EV_MFK120MAGNAMQBWB 005004
ROD: EV_MFK120MAGNAMQBWB_005_VW42.rod
Address C6: Battery Charger (J1050) Label file: None.
Part number SW: 5QS 915 684 J, Hardware part number: 5QS 915 684 E.
Component: HV_Charger H05 0060
Serial number: 94323YIH000I9
ASAM Dataset: EV_SAC3Phase11KM7MQBP 001009
ROD: EV_SAC3Phase11KM7MQBP.rod
VCID: 64957A8FCED9A91A0AB-8030-R SFD+SFD2
135172 - Engine Control Unit (ECU)
U0100 00 [00100000] - No communication.
[HVK_01_Timeout]
Error priority: 1.
Error frequency: 1.
Lost Count: 31
Mileage: 12 km
Date: 2026.04.14
Time: 11:20:05
147458 - Local data bus.
U10BA 00 [00100000] - No communication.
[UART interface error - COM port]
Error priority: 1.
Error frequency: 2.
Lost Count: 35
Mileage: 54 km
Date: 2026.04.15
Time: 14:36:48
417839 - Unknown error code.
U19FF 00 [00100000] - -
[grid_phase_dropout]
Error priority: 6
Error frequency: 1.
Lost Count: 39
Mileage: 435 km
Date: 2026.04.22
Time: 18:08:21
Address D6: Left lighting control 2 (A31)
Label file: 7PP-941-572.clb
Part number SW: 992 941 571 AK, Hardware part number: 992 941 571 A.
Component: LED1L H35 9204
ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
VCID: 6B8711B32307E6624B1-803E-R
Address D7: Right-hand lighting control 2 (A27)
Component: LED1R H35 9204
ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
Address 8105: 12V DC/DC converter (A19)
Label file: 5QS-907-195.clb
Part number SW: 5QS 907 195 E, HW: 5QS 907 070 C.
Component: DCDC Gen5 H12 1610
Revision: 00H12000
ASAM Dataset: EV_DCDC21010115QS907195E 001001
ROD: EV_DCDC21010115QS907195E.rod
VCID: 5DE34F6BEDB398D2C55-8008-R SFD+SFD2
"One error found:"
0111 - Diagnostic Interface Module SG, Unit 1.
U0146 00 [00101000] - No communication.
[Lost communication with serial data gateway module "A"].
Error priority: 6
Error frequency: 8
Lost Count: 0
Mileage: 122 km
Date: 2026.04.15
Time: 16:43:06
Address 8109: Short-range radar 1 (J1088)
Label file: * None
Part number SW: 3WA 907 541 F, HW: 95C 907 541.
Component: Nanoradar 1 H08 0162
Serial number: 36306005942952. Data version number: V03935470TX 0001.
Encoding: 59955E1529C405000000
ASAM Dataset: EV_NR1HELLAVW38X 002116
ROD: EV_NR1HELLAVW38X_002.rod
VCID: 4BC7B133434706622B1-801E-R SFD+SFD2
Address 810A: Short-range radar 2 (J1089)
Label file: * None
Component: Nanoradar 2, Part Number H08 0162.
Serial number: 36306005941850. Data version number: V03935470TM 0001.
ASAM Dataset: EV_NR2HELLAVW38X 002116
ROD: EV_NR2HELLAVW38X_002.rod
Address 810B: Short-range radar 3 (J770)
Label file: * None
Part number SW: 3WA 907 670 F, HW: 95C 907 550.
Component: Nanoradar 3, Part Number H09 0162.
Serial number: 10140125176660. Data version number: V03935478GA 0001.
Encoding: 59565E1529C405000000
ASAM Dataset: EV_NR3HELLAVW38X 002116
ROD: EV_NR3HELLAVW38X_002.rod
VCID: 4EC1B827B055334A4CF-801A-R SFD+SFD2
"One error found:"
12582983 - Initial setup not performed.
B2010 00 [00101110] - -
[No basic setting]
Error priority: 4.
Error frequency: 186.
Lost Count: 40
Date: 2000.00.00
Time: 00:00:00
Address 810C: Short-range radar 4 (J769)
Label file: * None
Component: Nanoradar 4, Part Number H09 0162.
Serial number: 10140125177171. Data version number: V03935478GC 0001.
Encoding: 99696E1631C40F000000
ASAM Dataset: EV_NR4HELLAVW38X 002116
ROD: EV_NR4HELLAVW38X_002.rod
[No basic setting]
Error priority: 4.
Lost Count: 40
Date: 2000.00.00
Time: 00:00:00
15859837 - Data bus received error value.
U1123 00 [00101110] - -
[error_value_VZM_Systemstatus_FASCANFD_FASCANFD2]
Error priority: 6
Error frequency: 63.
Lost Count: 40
Mileage: 455 km
Date: 2026.04.27
Time: 14:10:11
14680324 - Control unit for short-range radar.
U17EE 00 [00101000] - No communication on the Ethernet data bus.
[ethernet_databus_CommError]
Error priority: 5.
Error frequency: 1.
Lost Count: 33
Mileage: 253 km
Date: 2026.04.16
Time: 15:57:32
Address 813C: Charging Communication 1 (J1245) Label file: * None
Part number SW: 95C 907 594 ED. Hardware part number: 95C 907 594.
Component: SACID1 Aptiv H13 1043
Data record number: V03935417GA 0001.
Encoding: 3800C02000
ASAM Dataset: EV_SACID1CCSLowFKOMQBP 002062
ROD: EV_SACID1CCSLowFKOMQBP_002.rod
VCID: 7CA522EF566971DAD2B-8028-R SFD+SFD2
End -------- (Duration: 02:23, Battery voltage start/end: 13.3V/13.3V) ---------
--------------------------21 error codes found--------------------------
***End of LOG***
Translated on 11-08-2026, 20:33.
Post29-04-2026, 13:29    Subject: Golf 8: Missing File During Auto Scan (12/2025) Quote
Thank you! You can help with creating the files:
Okay, I understand. Please provide the German text you want me to translate into English. I will only provide the translation.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Missing ROD File - Seat Ibiza 1.6 TDI CR 2010 On-Board Diagnostics (OBD)
No new posts Fehlende Leistung beim AFN / suche Helfer mit VAGCOM On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. How to create a VCDS scan, and why? On-Board Diagnostics (OBD)
No new posts VCDS Scan: User Experience Could Be Better On-Board Diagnostics (OBD)
