Audi 80 Avant Wheel Alignment - Caster Adjustment
640Hatza
huebi likes this.
Post13-10-2026, 23:56    Subject: Audi 80 Avant Wheel Alignment - Caster Adjustment Quote
Hello everyone,
I recently took my Audi 80 Avant 1.9 TDI 1Z to a workshop for a wheel alignment.
The reason was that I had the two axles overhauled two years ago, but they were only roughly adjusted and installed.
I had adjusted the rear axle according to the manufacturer's specifications.
Furthermore, I installed a KW V1 coilover suspension system and adjusted it to a ride height of 320mm.
For the measurement, I drove with new tires icon_smile.gif.
What do you think about the set values?
Following the values, the collapse was not touched icon_sad.gif.
Can this be adjusted on a wheel alignment machine without the special tool?
Almost 1.5 degrees is quite a bit, isn't it?
Thank you in advance for your feedback.
 File size:  278.92 KB
 Viewed:  110 times
Translated on 13-10-2026, 23:58.
dieselschrauber likes this.
Post14-10-2026, 5:12    Subject: Audi 80 Avant Wheel Alignment - Caster Adjustment Quote
The camber is adjusted at the front by shifting the suspension ball joint against the control arm. Audi uses a special tool for this, but it can also be done without it (which I have done).
However, the camber will change with a lift or lowering. To achieve the optimal setting, you would need data from the suspension manufacturer, as the standard (1BA) camber may not be suitable for all ride heights. The off-road version is raised and exhibits less camber.
How is the alignment? Perhaps adjust the rear axle.
Translated on 14-10-2026, 15:39.
640Hatza
Post14-10-2026, 10:04    Subject: Audi 80 Avant Wheel Alignment - Caster Adjustment Quote
Thank you for your feedback.
The car drives very straight. When braking, it remains stable and doesn't pull to one side.
I'm generally satisfied with the driving experience, but it's quite sensitive to road imperfections.
My lowered Golf 7, for example, has a camber of just under -1° at the front.
I think I'll also set the Audi's suspension to -1°.
I have to go back there anyway because the mechanic didn't hold the tie rod end on one side while tightening it, which caused the rubber boot to get pinched.
Translated on 14-10-2026, 15:40.
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Audi A6 4F Instrument Cluster, VAG-COM. On-Board Diagnostics (OBD)
No new posts Audi Avant 2.5 TDI: Power Loss Troubleshooting Diesel Engine Technology
No new posts Audi 80 Avant TDI: Durable Chip Tuning On-Board Diagnostics (OBD)
No new posts Audi 80 Avant 1Z: Dynamic Injection Timing Type? Diesel Engine Technology
