P0321 Error: Faulty Crankshaft Sensor (VAG) (Solution)
Post28-09-2026, 7:09    Subject: P0321 Error: Faulty Crankshaft Sensor (VAG) Quote
Error code P0321 relates to the engine speed sensor (crankshaft sensor G28) and occurs in many VW/Audi/Seat/Skoda engines. The signal from the sensor is implausible or intermittently lost, which can lead to complete engine failure.
Typical error entry in the ECU:
000801 - Sensor for engine speed (G28).
P0321 - 000 - Implausible signal - Intermittent.
Environmental conditions:
Error status: 00110000
Error priority: 1.
Error frequency: 1.
Lost counter: 255
Mileage: 187,233 km
Time: 0.
Date: 2000.00.00
Time: 07:57:18
What does P0321 mean?
The crankshaft position sensor (G28) detects the engine speed and crankshaft position via a toothed wheel on the crankshaft. Without this signal, the engine control unit (ECU) cannot synchronize ignition and fuel injection. If the ECU detects an implausible or intermittent signal, a P0321 code is set. Common causes include a faulty sensor or an incorrect distance between the sensor and the toothed wheel.
Typical symptoms:
- Engine check light is on.
- Starting problems (engine doesn't start or starts with difficulty).
- The engine stalls while driving.
- The tachometer fluctuates or drops to zero.
- Stuttering
Most common causes:
- Faulty engine speed sensor (G28) (most common cause).
- Incorrect distance between the sensor and the encoder disc.
- Feeding wheel is dirty, damaged, or loose.
- Wiring/connector is corroded or damaged.
- Intermittent connection at the plug.
- If the donor variant is powered with +5V, check the power supply.
Diagnosis with VCDS:
- Autoscan: P0321 im Motorsteuergerät (01 - Motor)
- Observe the speed reading in the measurement block during the start attempt (if it remains at 0, there is no signal).
- Geber und Geberrad auf Verschmutzung/Beschädigung prüfen
- Measure the sensor's resistance and compare it to the target value.
- Check the connectors and wiring for loose connections.
Translated on 28-09-2026, 7:22.
Ratings - P0321 Error: Faulty Crankshaft Sensor (VAG)
No new posts P2563 Error: Turbocharger Overboost Fault (CR-TDI) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2101 Error: Throttle Actuator Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0380 Error: Glow Plug System Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Crankshaft Position Sensor (G28) & Starting Problems Diesel Engine Technology
No new posts Touran Crankshaft Position Sensor - Faulty Signal Diesel Engine Technology
No new posts 2.5 TDI Error Codes: AAT & More Diesel Engine Technology
No new posts Error code Diesel Engine Technology
