DPF Code P2463: High Soot Mass (Solution)
Post01-10-2026, 13:00    Subject: DPF Code P2463: High Soot Mass Quote
P2463 indicates excessive soot buildup in the diesel particulate filter – the filter is considered "full" by the control unit. The control unit detects that the regeneration process has not sufficiently reduced the amount of soot. A forced regeneration is then required.
What does P2463 mean?
The engine control unit calculates the soot mass in the diesel particulate filter, among other things, using the differential pressure sensor. If the soot accumulation exceeds a threshold, the code P2463 is set. This code indicates that the filter is too heavily loaded; the cause may be a failed or interrupted regeneration cycle, but it could also be a sensor error that simulates a false loading.
See also:
DPF not regenerating
Typical symptoms:
- Engine control light on (MIL).
- Power loss / limp mode under high load.
- Frequent or failed regeneration.
- Often combined with P2453 (Differential pressure sensor reading implausible).
Most common causes:
- Diesel particulate filter "full" (soot mass exceeds limit).
- Regeneration failed or stopped (short-distance operation).
- Incorrect load calculation due to a faulty differential pressure sensor.
- Outdated engine control unit (ECU) software / revised replacement parts according to TPI/TSB.
Diagnosis with VCDS:
- Autoscan: P2463 in the engine control module (01 - Engine).
- Check the soot mass in the measurement block.
- Initiate emergency regeneration.
- Check the differential pressure sensor and pressure lines (verify the plausibility of the load).
- Review TPI/TSB documents for manufacturer flash updates and revised replacement parts.
Translated on 01-10-2026, 13:07.
Ratings - DPF Code P2463: High Soot Mass
New posts P0402 Error: EGR Flow Too High Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3366 - System pressure (gas): too high Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2185 - Coolant Temperature Sensor, High Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF soot mass measured as too high Diesel Engine Technology
No new posts Exhaust Pressure Sensor Error: High Input Signal:( Diesel Engine Technology
No new posts Fehlercode 539 AFN nur Vmax 180! Verbrauch zu hoch! Diesel Engine Technology
No new posts Fehlercode 65535,Leerlauf ztw. nach dem Starten zu hoch On-Board Diagnostics (OBD)
