It would have been great to have
Autoscan and a log with load, air mass target/actual values (instead of just images).
If the
AGR flow rate is too high, then either the AGR valve is stuck and not closing properly, or air is being drawn in somewhere behind the MAF sensor (e.g., a leak in the intake manifold or the catalytic converter), and this air is not being measured.
