Audi A3: Syncing Key Fob (8V 2016)
KLU062
Post09-11-2026, 16:01    Subject: Audi A3: Syncing Key Fob (8V 2016) Quote
A3 Sportback 8V 2016 TDI 2.0
Dear forum members,
Does anyone know if it's possible to resynchronize the original remote keys using VCDS (current update RKS26090)?
Due to undervoltage during startup, the control unit ("central electronics") generated error messages and, among other things, activated the transport mode, which I have already deactivated.
I suspect that the keys are no longer synchronized, or that the control unit has lost the data.
What have I already tried!
1. Die Starterbatterie abgeklemmt (kpl. Reset).
2. Transport mode disabled.
3. All error entries (e.g., implausible findings) have been deleted.
4. All proposed methodologies (forums and AI) were tested without a diagnostic device.
I can't find any adjustment channels for this in control unit 09 (central electronics).
- The immobilizer is still working.
Has anyone else experienced this issue, or does it need to be reactivated by "customer support" through the manufacturer's server?
Sure, here's the translation:
"Thank you in advance."
Best regards, KLU062.
Translated on 09-11-2026, 16:03.
Karma: +1349 / -0   Thank you, like it!
dieselschrauber likes this.
Post09-11-2026, 18:43    Subject: Audi A3: Syncing Key Fob (8V 2016) Quote
Do you have any non-removable error entries or functional limitations? Without a clear indication, I would disregard the "assumption."
Autoscan?
Translated on 09-11-2026, 18:43.
KLU062
Post09-11-2026, 20:16    Subject: Audi A3: Syncing Key Fob (8V 2016) Quote
Hello Herbert,
Thank you for the quick response.
I had a scan performed, and it only showed error entries in the central electronic control unit and the engine control unit due to the low voltage. I cleared those errors, and they haven't reappeared.
Werde trotzdem am Wochenende nochmals einen kpl. SCAN.
Klaus.
Translated on 09-11-2026, 20:17.
KLU062
Post12-11-2026, 9:25    Subject: Audi A3: Syncing Key Fob (8V 2016) Quote
Hello everyone,
Short update.
The keys are working again.
After deleting all the error entries related to undervoltage, I performed another automatic scan, which showed no entries.
After that, I disconnected the starter battery for 5 minutes. In the first attempt I made regarding this, it was probably only 5-10 seconds, which was likely too short.
After that, it's reconnected, and then the usual warnings appear, such as "ESP etc."
What can I say, after that, the remote control worked again!!!
I'm not familiar with the logic of the central control unit, but it's likely that the "power supply voltage disaster" in the control unit caused something to be blocked, etc., and that the hardware reset triggered some change in the system!?
I don't know!
The most important thing is that it works again, without needing an expensive repair shop!
Wishing you all a good week and successful tinkering/working on projects.
KLU062
Translated on 12-11-2026, 12:35.
No new posts T5 Model 2014 Key Programming via VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Programming VW car keys from 1998 onwards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 Sportback: Retrofit Tow Hitch Installation Transmission, Chassis, Body & Interior
No new posts A3 Sportback - Eliminating road noise Transmission, Chassis, Body & Interior
No new posts A3 Sportback S-line suspension Transmission, Chassis, Body & Interior
No new posts Reset service interval for Audi A5 Sportback 2.0 Diesel On-Board Diagnostics (OBD)
