verdiener Guest
31-07-2003, 20:26 Subject: Best way to glue rubber: Tips & tricks. |
The rubber boot on my left tie rod end has a vertical cut. It hasn't completely torn through yet, but it's quite deep. I think the mechanics messed something up again.
What's the best way to cover up this cut? Does anyone know of a specific type of glue or something similar?
Translated on 02-10-2026, 3:55.
wollif Guest
01-08-2003, 7:55 Subject: Best way to glue rubber: Tips & tricks. |
I would try using bicycle tire repair tools.
Clean thoroughly, degrease, roughen the surface, and then apply it.
I'm sorry, I don't understand. Can you please rephrase your request?
Translated on 02-10-2026, 3:56.
DaBibo Blaumann
01-08-2003, 8:48 Subject: SEO: Best German to English Translation Services |
Actually, after roughening the surface, the steps are: apply, blend, wait, then apply again  .
Translated on 02-10-2026, 3:57.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
01-08-2003, 9:09 Subject: Best way to glue rubber: Tips & tricks. |
If it doesn't stick: use super glue.
Profile PM WWW Garage |
davidshoes Blaumann
Joined: 06/10/2002 Posts: 155 Karma: +6 / -2 Location: Sachsen
01-08-2003, 21:28 Subject: Best way to glue rubber: Tips & tricks. |
Cyanoacrylate adhesives (super glue) become too hard and brittle. First, degrease the surfaces with acetone or a similar solvent, and then roughen them. Afterwards, use a polyurethane adhesive (PUR), possibly with a hardener. I am a trained orthopedic shoemaker and therefore have experience with rubber materials and their processing.
verdiener Guest
02-08-2003, 15:21 Subject: Best way to glue rubber: Tips & tricks. |
@davidshoes
Where can I get a PUR adhesive like that? Can you recommend a specific product?
(Because if I go to the hardware store with that question, I'm guaranteed not to get a helpful answer, since they don't have the slightest idea here.)
Translated on 02-10-2026, 3:58.
davidshoes Blaumann
03-08-2003, 18:54 Subject: Best way to glue rubber: Tips & tricks. |
Perhaps you should use a bicycle tire repair kit, or you could ask a shoemaker (Synthek Total from Renia is the adhesive we use).
Translated on 02-10-2026, 3:59.
