Bosch MAF Sensors: Compatibility Guide
Arthur Dent
Post08-08-2003, 15:47    Subject: Bosch MAF Sensors: Compatibility Guide Quote
Unfortunately, despite an extensive search, I was unable to find a definitive answer as to whether the actual Bosch mass airflow sensor (MAF) components with part numbers 06a906461 and 028906461 are interchangeable or have identical performance characteristics. I am fully aware that the housings are different, and I am also familiar with the use of DC motors. What is puzzling me is the different Bosch part numbers for the components (F00C2G2056 vs. F00C2G2027), although I have also heard of many successful conversions.
So, what's the catch?
Thank you and best regards,
Thomas.
Translated on 13-08-2026, 1:21.
robertf
Post15-08-2003, 9:32    Subject: Bosch MAF Sensors: Compatibility Guide Quote
Hello Arthur!
I'm facing the same problem. I have a Bosch sensor F 00C 2G2 055 from a gasoline engine, which is supposedly only different in that it has a temperature sensor and is otherwise completely identical to the one installed in my car (F 00C 2G2 027). I'll try testing it tonight...
Does anyone happen to have an overview of Bosch parts? That would be very interesting.
Robert.
Translated on 13-08-2026, 1:22.
robertf
Post18-08-2003, 16:53    Subject: Bosch MAF Sensors: Compatibility Guide Quote
I bought a relatively inexpensive new housing (074 906 461 B) with a Bosch sensor (F 00C 2G2 055), and the seller claimed that it would also fit the ALH (and many other engine types). Unfortunately, after I asked again, he admitted that he was only selling parts from an insolvency case and didn't know anything else... Well, what doesn't one do to save 280 euros. icon_rolleyes.gif
The new housing has an additional internal tube with a finer mesh grid, and angled louvers at a 45-degree angle in front of it (presumably for lower airflow speed). Only the bottom part of the mass airflow sensor (MAF), which contains some copper pins or something similar, is inserted into this tube. The top part, with the bare sensing surface, remains outside in the normal airflow as before. What also strikes me is the changed design of the F 00C 2G2 055. My F 00C 2G2 027 has a straight bottom section with only one opening for the air to pass through. The F 00C 2G2 055, on the other hand, slopes downwards and has openings all over.
I almost suspect this is an improved version due to the numerous defects found in older models; the production date is May 2003. Has anyone on the forum received a brand new TDI and checked inside the air filter box to see if there are two grilles nested together?
Anyway, I installed the part in my old housing because there were no better alternatives, and the car now runs like new again icon_smile.gif. However, I still have a nagging feeling that this second pipe and the different design somehow need to match up, and that the mass airflow sensor isn't measuring correctly for me... icon_rolleyes.gif
So, if anyone has a clue what the numbers on the Bosch sensors mean or knows what is being measured in the lower part of the MAF sensor, please post it here!
Thank you very much.
Robert.
Translated on 13-08-2026, 1:25.
No new posts Grundeinstellungen für Bosch ABS/ESP 5.3 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts Error codes and possible causes for Bosch ABS Version 5.3... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kompatibilität Tdi Anlasser Diesel Engine Technology
No new posts Haldex Clutch Part Numbers & Compatibility Transmission, Chassis, Body & Interior
No new posts Zuheizer/Standheizung Audi Q7 Kompatibilität Diesel Engine Technology
No new posts Passat 1.9 TDI (AVF), Compatibility of Pump Nozzle Injectors Diesel Engine Technology
