Coolant fan control unit???
kapselchrissi
Post26-07-2003, 14:06    Subject: Coolant fan control unit??? Quote
hey folks,
I have a wiring diagram for a Climatronic in a Golf III 96 lying here and I'm about to lose it. I'm looking for the control unit for the cooling fan. It should have 2 fuses (20A and 30A), as well as a 10-pin connector and a 4-pin connector. It's important because it's also connected to the magnetic coupling for the air conditioning system. Thanks.
mersente
Post10-02-2004, 22:52    Subject: Coolant fan control unit??? Quote
Hello, please follow the cable from the fan or the thermistor on the cooler.
Where it is located is the control unit.
Martin R
Post11-02-2004, 20:21    Subject: Coolant fan control unit??? Quote
The control unit should be located near the coolant overflow tank.
No new posts P2185 - Coolant Temperature Sensor, High Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P261A, P261B - Pump for coolant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3BG AVB - Remove bearing from Visco fan Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kühlmittel G11 Diesel Engine Technology
No new posts Kühlmittel-Temperatursensor AFN Diesel Engine Technology
No new posts Error 4875: Coolant Pump 2 Diesel Engine Technology
No new posts Klimakompressor ohne Kühlmittel montieren? Transmission, Chassis, Body & Interior
