Passat 35i: Replace Rear Brake Discs
WarLord
Post28-07-2003, 20:41    Subject: Passat 35i: Replace Rear Brake Discs Quote
How can I replace the rear brake discs on a VW Passat 35i? To put it another way, how are they attached to the body of the car? (I'm not sure how else to phrase this question.)
Best regards, WarLord.
Translated on 24-08-2026, 10:04.
Post28-07-2003, 21:03    Subject: Passat 35i: Replace Rear Brake Discs Quote
Well, primarily, they are attached to the axle. Have you ever replaced the front ones? If not, I recommend getting a "Help Yourself" book. It has really good photos and explains the whole process clearly. If you've done it on the front before, it's relatively similar. First, you need to remove the brake caliper, which is attached with two screws on the left and right sides. Then, you need to loosen the cross screw (somewhere between two wheel bolt holes) --> usually, there isn't much you can do with a screwdriver there. I had to force it out. After that, all that remains is to remove the brake disc from the back. That wasn't easy for me either. I treated it heavily with rust remover, and eventually, I got it off.
Maybe you should take another look at a book, but with no guarantee... Matthias.
Translated on 24-08-2026, 10:05.
WarLord
Post28-07-2003, 21:08    Subject: Passat 35i: Replace Rear Brake Discs Quote
Okay, I watched the mechanic while he was removing the brake calipers. It's not rocket science. I just wanted to get a general idea of the process, especially what kind of screw it is that holds the rotor onto the axle (which you explained -> a Phillips head screw).
Translated on 24-08-2026, 10:06.
Albrecht
Post29-07-2003, 12:12    Subject: Passat 35i: Replace Rear Brake Discs Quote
The replacement of the rear brake discs is not the same process as replacing the front ones!
More like replacing a brake drum. The wheel bearing has to be removed along with it!
It's definitely worth getting the book!
Albrecht[/quote]
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
Translated on 24-08-2026, 10:07.
WarLord
Post29-07-2003, 14:06    Subject: Passat 35i: Replace Rear Brake Discs Quote
Well, I have someone else who can help me, so it won't be difficult.
Translated on 24-08-2026, 10:08.
sympatie
2020 Skoda Karoq
Post29-07-2003, 19:30    Subject: Reached the point? Find out now! Quote
where you want to push the brake piston back.
"So, if you don't have someone who knows about this to help you, just leave it alone!"
When retracting the brake pistons, you must rotate them. Before doing so, carefully lift or loosen the dust boot (otherwise it will rotate with the piston and tear).
Translated on 24-08-2026, 10:09.
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Brake Pads Replacement Rear Axle Transmission, Chassis, Body & Interior
No new posts Replacing rear brake discs and pads! Transmission, Chassis, Body & Interior
No new posts Rear Brake Discs 2.0 TSI Replacement Transmission, Chassis, Body & Interior
No new posts Replacing rear brake discs on a G3 - difficult? Transmission, Chassis, Body & Interior
