It's not always guaranteed that instrument clusters will fit in every vehicle. I retrofitted an instrument cluster with a Multifunction Display (MFA) from a 2002 T4 into my T4 from 2000. Some cables had to be connected, but it now works perfectly. However, if the instrument cluster doesn't already have an MFA, you can't add one. The MFA must be built into the cluster. If it is, you also need to install the steering column stalk and the corresponding cables.
Okay, have fun, Peter. VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 17-09-2026, 19:16.
