Wurstblinker Guest
29-07-2003, 16:11 Subject: Timing belt replacement: How many hours for a VW 1Z? |
Have the timing belt replaced on my Audi 80 TDI at a workshop.
How long does it typically take a skilled mechanic to do that?
'After replacing the fuel pump, does the injection pump timing need to be checked, or is this just a recommendation? What tools are required for this task?'
What is a reasonable price for a timing belt kit including tensioner and idler pulleys?
Thank you very much for your answers.
'MFG' stands for 'Mit freundlichen Grüßen,' which translates to 'Sincerely' or 'Best regards' in English. It is a common way to end a formal letter or email.
Translated on 24-08-2026, 22:49.
Rudi Guest
29-07-2003, 17:30 Subject: Timing belt replacement: How many hours for a VW 1Z? |
ich habe mit einem Bekannten zusammen (der KFZ Meister ist) incl. Control arms.
It took approximately 6 hours to replace the shock absorbers.
The start of the injection pump must be checked after changing the fuel pump.
Okay.
What tools does the mechanic need for this job?
Static: Torque wrench; dynamic: VAG tester / VAG-COM (unlocked).
What is a good price for a timing belt with tensioner and idler pulley?
I paid 69 euros for the kit from ContiTech.
Best regards, Rudi.
Translated on 24-08-2026, 22:51.
Joined: 04/12/2002 Posts: 18099 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
29-07-2003, 17:44 Subject: Timing belt replacement: How many hours for a VW 1Z? |
Hi Rudi,
Rudi wrote: | ...
Ugh... I paid way more for the CT946 K2 back then!
Were all the tensioning and redirecting rollers actually included with yours?
Can you provide me with a possible online source where I can purchase it?
Finding my luggage in Nuremberg was quite an ordeal.
Translated on 24-08-2026, 22:52.
Profile PM WWW Garage |
Manuel Thomas Guest
29-07-2003, 17:52 Subject: Timing belt replacement: How many hours for a VW 1Z? |
The price for that at Audi is €180!
So, it can't be much work!
Manuel.
Translated on 24-08-2026, 22:53.
Rudi Guest
29-07-2003, 19:54 Subject: Timing belt replacement: How many hours for a VW 1Z? |
Hello Rainer,
'On my 1Z engine, it was the CT867 K4 with a timing belt and tensioner.'
and a pulley.
... Can you tell me a possible online source where I can find it? ...
Unfortunately not. I got it here locally, directly from the dealer.
Best regards, Rudi.
Translated on 24-08-2026, 22:54.
joergs Guest
30-07-2003, 6:39 Subject: Timing belt replacement: How many hours for a VW 1Z? |
'With my 1Z, it took me a good 4 hours last year to do it alone, taking things slowly! But I think an experienced mechanic could probably do it in about half that time!'
@rainer, rudi
I don't exactly remember which ContiTech ZR-kit it was, but I paid around 110 euros for it.
Translated on 24-08-2026, 22:55.
Mc_Givertechnik Schrauber
Joined: 02/27/2003 Posts: 390 Karma: +3 / -0 Location: Graz Österreich 2010 Volkswagen T5 Premium Support
30-07-2003, 8:49 Subject: Timing belt replacement: How many hours for a VW 1Z? |
The workshop I trust charged me 4.5 hours for the timing belt replacement.
Regards, Peter. VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 24-08-2026, 22:56.
Profile PM Email Garage |
joergs Guest
30-07-2003, 8:55 Subject: Timing belt replacement: How many hours for a VW 1Z? |
'I think that's also the standard time specified by AUH Weh! But a skilled mechanic might not necessarily need that much time! I'm talking about a 1Z engine in a Passat 35i, which is relatively easy to access without having to disassemble half the car, and without needing those Russian-made reinforced corner brackets and lifting pads!'
Translated on 24-08-2026, 22:57.
Wurstblinker Guest
30-07-2003, 9:51 Subject: Timing belt replacement: How many hours for a VW 1Z? |
Hi there!
I just spoke with a one-man workshop.
The price for the replacement is €75. The timing belt with tensioner and idler pulley costs me €70 (I believe it's from Bosch).
I think the prices are good; I'll get it done tomorrow.
The Audi now has almost 300,000 kilometers on the odometer.
The last oil change was at 190,000 km, so it's definitely time for another one. Well, that's just how it is when you're a poor student  .
Have I understood correctly that the fuel injection pump can be adjusted using a dial indicator without a VAG-COM diagnostic tool?
Thank you all very much.
Best regards, Wurstblinker.
Translated on 24-08-2026, 22:58.
joergs Guest
30-07-2003, 9:55 Subject: Timing belt replacement: How many hours for a VW 1Z? |
That's a great price! Is there perhaps a catch? Otherwise, that would be the first workshop I know of that doesn't try to profit from it.
You are really brave with the 'extended interval'!
Translated on 24-08-2026, 23:00.
Rudi Guest
30-07-2003, 10:01 Subject: Timing belt replacement: How many hours for a VW 1Z? |
Did I understand correctly that the fuel injection pump can be adjusted without a VAG-Com using a measuring gauge?
statically (with the engine idling), using a gauge;
dynamic (running engine), e.g., using VAG-COM.
Best regards, Rudi.
Wurstblinker Guest
30-07-2003, 10:02 Subject: Timing belt replacement: How many hours for a VW 1Z? |
Is there an advantage to making it dynamic?
He doesn't make much profit from it.
But do you have 75 euros or not?!
@Rudi
Where in Schleswig-Holstein are you from?
I am from Kiel.
Sausage blinkers.
Translated on 24-08-2026, 23:02.
30-07-2003, 10:03 Subject: Timing belt replacement: How many hours for a VW 1Z? |
"Hi,"
Yes, the price is great. But what if, like in my case, some of the screws won't come loose?
"The mechanic would be really annoyed to have to deal with such a small amount of flakes... or is this a problem specific to Poland/Croatia?"
Translated on 24-08-2026, 23:03.
joergs Guest
30-07-2003, 10:05 Subject: Timing belt replacement: How many hours for a VW 1Z? |
statically (with the engine at idle), using a dial gauge;
However, it should be noted that the static settings should only be a baseline, and ideally, they should be dynamically adjusted as soon as possible! In my case, I had to make several corrections dynamically after the initial static setup in order to bring the values back within the acceptable range according to the diagram.
Translated on 24-08-2026, 23:04.
haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
30-07-2003, 10:08 Subject: Timing belt replacement: How many hours for a VW 1Z? |
Wurstblinker wrote: | | Did I understand correctly that the fuel injection pump can be adjusted without a VAG-Com using a measuring gauge? |
Hi Wurstblinker,
It's better not to adjust it using a precision meter. The discrepancies between the precision meter and VAG-COM were extreme in my case (see the search function "White smoke") -> the entire forum was busy for weeks because I didn't want to believe that the readings from the precision meter on the TDI seemed unusable.
"I need 6-8 hours for a timing belt replacement, but I also take my time and always replace all safety-critical screws and nuts, and I double-check the valve timing (and torque specifications) multiple times." ____________
Kein Auto mehr!
Translated on 24-08-2026, 23:05.
Wurstblinker Guest
30-07-2003, 10:16 Subject: Timing belt replacement: How many hours for a VW 1Z? |
If he doesn't have a VAG-COM device, can I still get it adjusted somewhere else?
What I don't quite understand is that the valve timing seems to be within acceptable limits now; at least, that's what I assume, since it doesn't seem to be producing excessive smoke or anything like that.
For the timing change, both the injection pump gear and the camshaft are fixed in place;  so why could anything then become misaligned?
@Rainer,
What kind of screws could it be that might be stuck?
You really don't have to solve that many.
Translated on 24-08-2026, 23:07.
