joe Guest
06-08-2003, 11:18 Subject: Audi A3 Immobilizer Malfunction: Fix It Now! |
Today, I started my A3 TDI with the 1Z engine, no problem. I stopped briefly at the bakery, and when I tried to start it again, the engine turned off, and the immobilizer light came on.
I then waited for about 20 seconds with the ignition on, and the immobilizer light went off, and the engine could be started again.
What is it? Is the control unit malfunctioning, or is it a problem with the key?
Or is it the cash register in the bakery that is interfering with my control unit?
Translated on 04-09-2026, 11:33.
Tagessuppe Profi-Schrauber
Joined: 11/13/2002 Posts: 1142 Karma: +38 / -0 Location: Wien 2001 Audi A2  Premium Support
06-08-2003, 11:48 Subject: Audi A3 Immobilizer Malfunction: Fix It Now! |
Wie? Der A3 hat den 1Z Motor? I'm not familiar with that.
Did you unlock the car with the FFB (Force Feedback) or with a key?
Translated on 04-09-2026, 11:34.
Profile PM Garage |
joe Guest
06-08-2003, 12:00 Subject: Audi A3: Jetzt auch mit 1Z! |
Hello, it's a 1997 A3 with a 90 horsepower 1.6 engine.
I unlocked the car using the aftermarket remote control.
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
06-08-2003, 16:00 Subject: Audi A3 Immobilizer Malfunction: Fix It Now! |
Okay, I also don't know of any A3 models that come standard with a 1Z engine.
The 1Z was installed in the following Audi vehicles during the model years '96 and '97:
4A2 - A100/A6
4A5 - A100/A6 Avant
8C5 - Audi 80 Avant
8D2 - A4
8D5 - A4 Avant
8G7 - A4 Convertible.
What does the error memory say?
Tschüss
Michael II
Translated on 04-09-2026, 11:35.
joe Guest
07-08-2003, 11:21 Subject: Error Fixed! Solution Now Available. |
Hello, the problem is gone. I really suspect the cash register of the bakery. It was only 3-4 meters away from my car.
Today, I will read the error codes.
What are the engine codes for the 90 hp TDI engine in the A3?
Translated on 04-09-2026, 11:37.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
07-08-2003, 11:53 Subject: Bug fixed! |
joe wrote: | ...
What are the engine codes for the 90PS TDI in the A3? |
It's located on a sticker in the service booklet or in the trunk under the carpet.
Profile PM WWW Garage |
joe Guest
08-08-2003, 6:18 Subject: AGR Loan: What it is & How it Works |
As I said, the error is gone! I will read the error memory soon.
Translated on 04-09-2026, 11:38.
werwolf07 Guest
08-08-2003, 9:22 Subject: MKB: Meaning, Causes, and Treatment |
I guess that refers to the 66kW engine with MKB and AGR.
Wolfgang.
Translated on 04-09-2026, 11:39.
joe Guest
11-08-2003, 7:07 Subject: AGR: Yes, it is! |
Hello, so it's an AGR with 90 horsepower.
The error is gone, and the error memory is clear, so it was probably some kind of interference.
