TDI 90 PS: No Power? Troubleshooting Guide.
sticki
Post13-08-2003, 20:10    Subject: TDI 90 PS: No Power? Troubleshooting Guide. Quote
Hi!
I'm asking this on behalf of a friend who is currently on the highway. He suddenly experienced a loss of power across the entire RPM range, and the turbo is no longer boosting (TDI 90hp with a chip, tuned to ~120hp).
All I know is that it could be a Mass Air Flow (MAF) sensor issue. I've only experienced this once before, and in that case, it manifested as a brief burst of turbo boost, but then, apparently, the MAF sensor was providing incorrect values at 3000 rpm, which prevented the engine from exceeding 3500 rpm.
What could it be if the engine has no power across the entire RPM range? Its top speed seems to be only just over 110 km/h... at first glance, it sounds like a turbocharger problem to me... what do you think?
best regards, marc
Translated on 07-10-2026, 10:32.
Post13-08-2003, 20:27    Subject: TDI 90 PS: No Power? What's Broken? Quote
sticki wrote:
He suddenly experienced a loss of power across the entire RPM range, and the turbo is no longer providing boost (TDI 90HP with chip, approximately 120HP).
What could it be if the engine has no power across the entire RPM range? Its maximum speed seems to be only just under 110 km/h... at first glance, it sounds like a turbocharger problem to me... what do you think?
Hi Marc,
TDIs are characterized by the fact that various underlying causes can be responsible for the same or similar symptoms. If you delve into the relevant scientific articles, you'll get an idea of why "no power" is practically useless for making a reliable diagnosis.
Translated on 07-10-2026, 10:34.
sticki
Post13-08-2003, 20:34    Subject: TDI 90 PS: No Power? What's Broken? Quote
He suddenly experienced a loss of power across the entire RPM range, and the turbocharger is no longer providing boost (TDI 90HP with chip, approximately 120HP).
What could it be if the engine has no power across the entire RPM range? Its top speed seems to be only just under 110 km/h... at first glance, it sounds like a turbocharger problem to me... what do you think?
Hi Marc,
TDIs are characterized by the fact that various causes can lie behind the same or similar symptoms... If you delve into the relevant technical articles here, you'll get an idea of why 'no more power' is practically useless for a reliable diagnosis. }
I had already narrowed it down a bit... it seems to be happening across the entire RPM range, and the turbo doesn't seem to be engaging at all.
I've already read most of the articles... I'll take another look.
Translated on 07-10-2026, 10:36.
cz26m
Post15-08-2003, 13:53    Subject: TDI 90 PS: No Power? Troubleshooting Guide. Quote
hi
Maybe this will help. I once had a small hole in the blue vacuum hose of the turbocharger, caused by a badger bite. The car could only go about 75 mph, and I missed the turbo whistle. I patched the hose, and everything was okay again. Maybe something is leaking.
look, chris.
Translated on 07-10-2026, 10:37.
Post15-08-2003, 14:06    Subject: TDI 90 PS: No Power? Troubleshooting Guide. Quote
blue vacuum hose of the turbocharger.
On the 1Z (90 SP TDI) engine, there are no vacuum hoses connected to the turbocharger. Only pressure hoses (i.e., boost pressure or "adjusted" boost pressure).
Translated on 07-10-2026, 10:38.
sticki
Post15-08-2003, 15:43    Subject: TDI 90 PS: No Power? Troubleshooting Guide. Quote
The issue has been resolved. He took the car to the workshop, and it turned out to be the mass airflow sensor (MAF). Thanks to everyone for their help!
Translated on 07-10-2026, 10:39.
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger/Compressor System No Power - P2263 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM Failure: No Power? Get Help Now! On-Board Diagnostics (OBD)
No new posts Car Not Starting? No Power? Troubleshooting Diesel Engine Technology
No new posts TDI 2.5 T4 engine no longer provides performance. Diesel Engine Technology
No new posts 1Z Engine: No Power? Troubleshooting Guide. On-Board Diagnostics (OBD)
