Can you adjust the boost pressure with VAG-COM on an Audi B4 (1Z)?
thom
Post02-10-2003, 18:41    Subject: Can you adjust the boost pressure with VAG-COM on an Audi B4 (1Z)? Quote
Hello
Maybe the question sounds a bit silly (I used the search function), but I wanted to test my old turbocharger in my Audi B4 (1Z) from 1993 today to see how much boost it still produces. It's the first turbocharger I ever had, and it has 330,000 km on it. I connected my laptop to the car, first read out the error memory, but there was nothing. I also need to mention that I always have to increase the start baud from 0 to 240 first, otherwise nothing happens. Then I went to the measurement block. I hope it was correct, but when I tried to access the different groups, I got an error message saying "not found". Could it be that the car is too old and the control unit simply can't do it, or am I just being misled?
Maybe someone can tell me how to do this? When I once replaced a single ABS sensor, I was also able to read the current speed of each individual wheel in the measurement block.
Best regards
thomas
Back to top Profile PM Email
No new posts Calix Motor Heater Installation Guide Troubleshooting & Guides
No new posts Glow Plug Information: Types, Function & More Technical Articles
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kann man einen Drehzahlmesser in AUDI B4 TDI einbauen ? Diesel Engine Technology
No new posts Kann man einen belibigen LLK nehmen? Golf 3 1.9td Bj.92 55kW Diesel Engine Technology
No new posts vagcom auf pocketpc?!? On-Board Diagnostics (OBD)
No new posts ladedruck nur 0,6 bar... Diesel Engine Technology
