VAG-COM: Check Injection Start - Free Software?
ChristianF
Post21-08-2003, 16:13    Subject: VAG-COM: Check Injection Start - Free Software? Quote
Hello, I only have the VAG-COM shareware version 303.2.
The TDI graph used to check the injection start timing is therefore not available to me.
My question is: how can I check the dynamic fuel injection start timing of my ALH engine using VAG-COM? I would ideally like to use the graph for this; is there a way to do that?
Christian.
Translated on 24-08-2026, 10:56.
Post21-08-2003, 19:00    Subject: VAG-COM: Check Injection Start (Free?) Quote
The TDI graph used to check the start of injection is therefore not available to me.
My question is: how can I check the dynamic fuel injection start of my ALH engine using VAG-COM? I would actually like to use the graph for this; is there a way to do that?
Hi Christian,
The graph is, as far as I know, necessarily linked to an unlocked version.
An approximate indication icon_exclaim.gif is also possible during full-load operation up to 4000 rpm; however, the duty cycle at the injection control should not increase significantly above 90% (see technical articles on pump adjustment).
Translated on 24-08-2026, 10:58.
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku keine Umcodierung möglich, 01K-01F Automatikgetriebe Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Spritzbeginn etc. mit VAG 1551 Tester überprüfen. (AEL) Diesel Engine Technology
No new posts Controlling the injection timing (AFN) with shareware VAG... On-Board Diagnostics (OBD)
No new posts VAGCOM Shareware in deutsch? Diesel Engine Technology
No new posts Gibts VAG-Com Shareware mit der ich die WFS anpassen kann? Diesel Engine Technology
