Crankcase Ventilation: System & Solutions
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Steffen
Post25-08-2003, 19:36    Subject: Crankcase Ventilation: System & Solutions Quote
I replaced the original air filter housing on my TDI with a carbon airbox (with an integrated filter). However, the airbox doesn't have a fitting for the crankcase ventilation hose.
Does it have any (negative) consequences if the hose is now hanging freely?
It would be great if someone could explain that to me!
Best regards, St.
Translated on 23-10-2026, 1:37.
christians
Post25-08-2003, 20:18    Subject: Crankcase Ventilation: System & Solutions Quote
There was a discussion about that before.
In short:
-You will lose your certification, with all the legal consequences that entails (the exhaust gases contain a high level of pollutants).
-You're messing up the engine compartment.
-Whether the valve guides need oil is a matter of debate.
Gruß Christian
Translated on 23-10-2026, 1:38.
Steffen
Post25-08-2003, 21:17    Subject: Crankcase Ventilation: System & Solutions Quote
But the hose is attached to the top of the original air filter housing, *after* the air has been filtered, so there shouldn't be any pollutants or anything else in it, right?
Translated on 23-10-2026, 1:39.
No new posts AEY 1.9 SDI VP37: Start & Bleed Procedure Diesel Engine Technology
No new posts VP44 Bleeding: Forum User Question Diesel Engine Technology
No new posts Cooling circuit ventilation not starting - safety error On-Board Diagnostics (OBD)
