Clutch Squeal: A3 Documentary (Solution)
Michael II
Post29-08-2003, 8:16    Subject: Clutch Squeal: A3 Documentary Quote
Squeaking noises only occur in the upper portion of the clutch pedal travel when the clutch pedal is depressed.
Up to chassis number: 8L1A091087.
Cause:
The clutch pedal switch is rubbing against its mounting bracket or the contact surface on the clutch pedal.
Solution:
Check the clutch pedal switch for proper operation and, if necessary, lubricate the protruding end with polyurethane grease (G052 142 A2).
Note: The clutch pedal switch is designed for single use only. Repeated installation and removal of a switch will wear down the locking tab.
Tschüss
Michael II
Translated on 21-09-2026, 5:29.
Ratings - Clutch Squeal: A3 Documentary
No new posts A3 Clutch Squeak: Repair Guide & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D: Brake Squeal Noise - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dacia/Renault Duster, squeaking noises steering column / ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coupling Diesel Engine Technology
No new posts A4 8K SAC Clutch: Replacement & Upgrade Transmission, Chassis, Body & Interior
No new posts Clutch 1Z Diesel Engine Technology
No new posts LUK Clutch for ALH engine Diesel Engine Technology
