Illumination of ventilation ducts
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
GM60
Post14-11-2002, 11:18    Subject: Illumination of ventilation ducts Quote
On my Passat Variant 3B AFN, manufactured in 1999, the indicator lights from the ventilation vents (right side of the middle and passenger side) have stopped working. Is there a fuse for this, or are the indicator lights/LEDs themselves faulty? Where and how can I, if it's the bulbs, replace them without breaking or scratching various parts?
Best regards, Paul
Jürgen
Post15-11-2002, 15:00    Subject: Illumination of ventilation ducts Quote
hello,
I did this on my wife's Passat (Bj99) once. First, you have to remove the entire air intake. However, this is not as easy as described in the manuals, and in my case, it ended with me having to buy a new middle air intake from VAG (around €50). When I was at VAG, they had about 10 pieces in stock. The mechanic said, 'They always break when you remove them!' The screws at the back cannot be removed with standard tools.
My summary: I will wait until all 4 pears are defective.
- The lighting is unnecessary! At
There are none in my Golf IV.
and that works perfectly too!
Hello, Jürgen
andreas
Post20-11-2002, 17:04    Subject: Illumination of ventilation ducts Quote
Hello Paul!
Here's a link to a page where you can find instructions on how to install air vents, among other things.
It worked perfectly on my 3B, 07/97!
http://vw.golz.info/modified-parts/
Greetings
Andreas
Jürgen
Post21-11-2002, 14:21    Subject: Illumination of ventilation ducts Quote
Hello Andreas,
I had this instruction too, and I am definitely
- not clumsy - but it was not easy to get it out. The information from VAG was 'They are gone.'
most often break during expansion, therefore they are always on
'Warehouse'. Furthermore, the construction with the retaining brackets is really very strange and designed to fail. Should be again
I'll just throw the apple away, I don't want to waste my time.
Best regards, Jürgen
Passat AFN, manufactured before 1999 / G4 AHF, manufactured before 1999 - please, no PD!
Claw
Post07-08-2003, 14:51    Subject: Illumination of ventilation ducts Quote
Hi, I can only confirm what's here and advise against removing the air vent yourself. I tried it today (the one on the left, at the front) and it broke for me too. Cost: €53!! icon_cry.gif
Juan
Post21-08-2003, 10:49    Subject: Illumination of ventilation ducts Quote
I would like to kindly refer to the following link:
http://www.passatplus.de/umbauteile/ausstroemer/luftausstroemer.zip
Madness
Post01-09-2003, 15:11    Subject: Illumination of ventilation ducts Quote
At the Passi, the ventilation outlets use standard incandescent light bulbs.
With a little skill, you can replace them with LEDs.
And the vents work really well when you set the heater to full power and let all the air come out through the vents.
Due to the heat, the plastic becomes soft/elastic and doesn't break when removed icon_wink.gif
No new posts Doku A2 8Z0 MJ 2002, Beleuchtung Kombiinstr. fehlerhaft Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Passat MJ 2000 Beleuchtung Sonnenblende defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2002, Beleuchtung CD-Spieler flackert Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Beleuchtung Diesel Engine Technology
No new posts Klimaanlage- Beleuchtung Diesel Engine Technology
No new posts Beleuchtung an der Climatronic Transmission, Chassis, Body & Interior
No new posts VW-Blaue Beleuchtung, technische Daten Diesel Engine Technology
