Hi!
I've already been searching... and I've also found something. But nothing for my question!
Yesterday, my Golf 3 TDI (1Z) failed to start once. Since then, it has been occasionally stalling with a strong exhaust smoke! It occurs sporadically...
Error codes according to VAG-COM:
00513 G28 Encoder Motor Speed
No signal, intermittent
According to the error database: Cable break/Short circuit
Another cable broken!? Okay, now here's my question:
Which cable? From pin 2 to the MCU? And where could the error be?
...it probably happens more often...
Should I best immediately pull a new cable from the STG to the G28, or should I first measure, which might be okay because it's only sporadic
How does the G28 work... or why is there a sensor mass and a mass, and a cable to the controller!?
Why not just one mass, if he can switch it?
Thank you for all the answers!
Best regards, Matthias
