VW Beetle Control Unit
Gummibaer1256
Post19-09-2003, 20:05    Subject: VW Beetle Control Unit Quote
Hello everyone,
I drive a VW Beetle 1.9 TDI with 66 kW.
Can someone tell me where the control unit is located?
Thank you very much.
Best regards, Gummibaer1256.
Translated on 01-10-2026, 14:55.
Michael II
Post20-09-2003, 20:54    Subject: VW Beetle Control Unit Quote
I assume you're referring to the engine control unit (ECU).
Slide the middle cover of the water tank housing forward from its retaining clips and remove it from the control panel.
Remove the three screws located underneath.
Lift the left cover of the water tank located in the center of the control panel and detach it (clips at the front edge, brackets at the rear edge).
Pull the cover towards the center of the vehicle from the holder located below the A-pillar.
Lift the right-hand cover of the water tank located in the center of the control panel, and detach it (the front edge has clips, the rear edge has brackets).
Pull the cover from the center of the vehicle towards the bracket located below the A-pillar.
Unscrew the fastening screws from either the right or left locking mechanism, and then detach the locking mechanisms by lifting them upwards from the water tank.
Then you should see the STG.
Tschüss
Michael II
Translated on 01-10-2026, 14:57.
Gummibaer1256
Post21-09-2003, 20:57    Subject: SEO: Best Practices for Website Optimization Quote
Thank you for the quick response. I was almost going crazy. icon_biggrin.gif
Translated on 01-10-2026, 14:58.
No new posts Gear Housing Service: VW Golf IV & New Beetle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rear-axle Beetle Transmission, Chassis, Body & Interior
No new posts VW New Beetle: Program Remote Key Fob On-Board Diagnostics (OBD)
No new posts VW New Beetle: Radio Gateway Replacement Dieselschrauber Bar
No new posts Beetle 2004 1.4 BCA - No Label File On-Board Diagnostics (OBD)
