Engine Vibration at Idle (ALH)
Lichtschalter
Post04-09-2003, 18:48    Subject: Engine Vibration at Idle (ALH) Quote
Hello everyone.
Lately, it has become increasingly common for the engine to start vibrating noticeably.
Whenever I've driven a long distance or when I'm driving fast.
I've also already read the error codes, but without success.
Now, recently, he's also noticed that the engine immediately goes to idle speed when started, but then it misfires (the RPM briefly drops to around 700-800 RPM).
It is also quite noticeable.
Has anyone else experienced this problem? If so, what helped to resolve it?
Light switch.
Translated on 26-09-2026, 19:10.
Michael II
Post04-09-2003, 19:09    Subject: Engine Vibration at Idle (ALH) Quote
What do the values of measurement group 13 indicate in the engine control unit (ECU)?
Are the air and diesel filters in good condition?
Tschüss
Michael II
Translated on 26-09-2026, 19:11.
Lichtschalter
Post09-10-2003, 19:03    Subject: Engine Vibration at Idle (ALH) Quote
It's been a long time since I posted this problem here.
I thought maybe the problem was with the chip, and after a long time, I finally removed the chip, and sure enough, the problem was resolved on its own.
By the way, I didn't look at the values because I suspected from the beginning that the problem was with the chip.
Light switch.
Translated on 26-09-2026, 19:12.
No new posts Document: MKB AKF, Vehicle vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B Headlight Vibration: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Idle running issue, V8 TDI 3.3L AKF engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 Engine BGU, Jerking/Unstable Idle Gasoline Engine Technology
No new posts Engine Misfire: Warm & Cold Starts (13/18/23) Upload
No new posts Rough Idle in Hot Weather: Causes & Fixes Diesel Engine Technology
No new posts 1.9 TDI AWX: Idle Jerking/Stalling - Causes & Fixes Diesel Engine Technology
