Golf 3 Suspension Bushings: Replace Front & Rear
MarkusAFN
Post23-09-2003, 15:05    Subject: Golf 3 Suspension Bushings: Replace Front & Rear Quote
I have a Golf 3 AFN (with a plus-sized axle) and have been driving it for about 80,000 km with a sports suspension (KW springs 60/40, Bilstein dampers) and for 25,000 km with a set of 7.5x16 inch wheels with 215 40 R16 tires.
Meanwhile, I'm noticing that the bearings in the suspension are definitely being affected. icon_cry.gif
Now I'd like to ask if anyone has any experience with replacing bearings.
front:
Trailing arms attached to the body.
Trailing arms on wheel carriers.
rear:
Cross-linked steering axis to body.
The strut mounts have already been replaced.
Is it very complicated to replace the bearings? Are the bearings pressed in?
'How much does a set like that usually cost?'
Thank you.
Translated on 29-08-2026, 9:29.
Albrecht
Post23-09-2003, 17:05    Subject: Golf 3 Suspension Bushings: Replace Front & Rear Quote
Hello Markus,
It's all tedious work! To simplify things, I would replace the entire control arms with new ones, including the bearings.
best regards
Albrecht.
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
Translated on 29-08-2026, 9:30.
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Golf3 pulls to the left (SOLVED) General Tips
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Golf 3 TDI: WFS 1Z Performance Parts Diesel Engine Technology
No new posts Automatic Transmission Volkswagen Golf 3 Transmission, Chassis, Body & Interior
No new posts Chip Golf 3 Diesel Engine Technology
No new posts Boost Gauge for VW Golf 3 Diesel Engine Technology
