When accelerating, the engine power will be reduced.
zipzilla
Post27-05-2002, 17:39    Subject: When accelerating, the engine power will be reduced. Quote
hello,
I've been dealing with this issue for quite some time now. So far, no one has been able to help me. Specifically, when the outside temperature is less than 5°C, the performance drop of my V6 is worse than with the Trabant, meaning it doesn't pull at all; it only starts to perform properly once it reaches a certain temperature. I'm now having the pleasure of testing a different M-ECU, but as you can see, the temperatures are not sufficient. And I only have 14 days to test it?
does anyone have any ideas, what it could be and what I should do now? icon_eek.gif
Best regards
zipzilla
afb/99er/new LMM/no salad oil/ icon_lol.gif
Tortsch
Post28-05-2002, 7:39    Subject: When accelerating, the engine power will be reduced. Translating...
[Translating...]probier es mal mit eissprya an bestimmten punkten abzukülen und dann testen woran es leigt icon_cool.gif
zipzilla
Post28-05-2002, 18:46    Subject: When accelerating, the engine power will be reduced. Translating...
[Translating...]hallo,
mfg
zipzilla
Tortsch
Post29-05-2002, 8:29    Subject: When accelerating, the engine power will be reduced. Translating...
[Translating...]bei meinem Kollegem trat ein unruiger motorlauf im erwärmten zustand auf da hat der ADAC mensch den motor direkt eingesprüht....aber vieleicht hat hier ja jemand och ne idee icon_idea.gif
Karma: +786 / -0   Thank you, like it!
Post29-05-2002, 9:59    Subject: When accelerating, the engine power will be reduced. Translating...
[Translating...]
wenn der Motor kalt ist, folgendes checken:
- Laderverstellung leichtgängig (hier kannst nix sprühen, da ist eher die Kältemittel Dose leer als der Lader kälter)
- Abstelldrosselklappe (falls vorhanden) leichtgängig und in der richtigen Position (offen)
- Alle elektrische Verbindungen, Geber und evtl. Steuergerät selbst abkühlen
Tip: seh Dir mal die Werte der Temperatursensoren (Motor, Ladeluft etc.) an wenn er so mies läuft. Was mich allerdings irritiert, ist daß nix im Fehlerspeicher steht; könnte also auch am Steuergerät selbst liegen.
Grüße, Rainer
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Nach VCDS Update wird HEX-USB+CAN nicht gefunden General Tips
No new posts What is the synchronization angle in a TDI engine? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts lautes Brummen beim beschleunigen Diesel Engine Technology
No new posts Ruckeln, Schleifen beim beschleunigen und anfahren..... Diesel Engine Technology
No new posts Passat 1Z: Handbremsleuchte geht beim beschleunigen an! Diesel Engine Technology
No new posts Sharan 1,9tdi 4 Motion- extremes Dröhnen beim beschleuni... Diesel Engine Technology
