Increase initial fuel quantity with VAG-COM on A6 V6 TDI
GarfieldMZ
Post30-05-2002, 13:28    Subject: Increase initial fuel quantity with VAG-COM on A6 V6 TDI Quote
Hello everyone!
To my knowledge, the starting quantity can be adjusted using VAG-COM. I wanted to try this because I occasionally have some problems with the engine starting, both when it's warm and cold. These problems are not severe, and it usually starts on the second attempt. The injectors and glow plugs are also fine. That's why I just wanted to try it this way.
Does anyone know what the correct login is and where I can change the initial amount?
Has anyone else experienced similar problems with starting the engine, or has anyone tried using a different amount of fuel?
Thank you for your information!
DENNIS
Michael II
Post30-05-2002, 18:16    Subject: Increase initial fuel quantity with VAG-COM on A6 V6 TDI Quote
I have entered it into the error database.
Tschüss
Michael II
No new posts Document startup issues, adjusting initial quantity Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Startmenge erhöhen Diesel Engine Technology
No new posts Increase Startup Amount with Diagnostic Tool Diesel Engine Technology
No new posts Increase the starting fuel quantity for a 2.5 TDI AAT/96 ... Diesel Engine Technology
No new posts Ladedruck erhöhen beim ALH Motor / Brauche dringend Hilf... Diesel Engine Technology
