Heiner Guest
21-10-2003, 23:51 Subject: TDI Engine Jerks at 2150-2200 RPM |
I have a question. My TDI 110 kW PD engine jerks during driving at approximately 2150/2200 RPM. It's a brief jerk, as if there's no fuel or power available. Then it continues driving normally.
'At VW, they couldn't find anything in the error memory, so according to the dealer, there's no fault. They weren't willing to replace any parts. So what now? My warranty expires in 6 months, and it's really bothering me.'
Perhaps someone has a tip? Unfortunately, this 'interruption' doesn't always occur, and I can't make it happen intentionally.
Best regards, Heiner.
Translated on 16-10-2026, 10:11.
22-10-2003, 17:15 Subject: TDI Jerking: Troubleshooting at 2150-2200 RPM |
Heiner wrote: | My TDI 110 KW PD engine jerks during driving at approximately 2150/2200 RPM. It's a short jerk, as if there's no fuel or power available. Then, it continues driving normally.
At VW, nothing could be detected in the error memory, so according to the dealer's statement, there is no fault. They didn't want to perform any arbitrary parts replacements. And now what? |
Hi Heiner,
Connect a laptop with VAGCOM and log the relevant "suspicious" measurement groups during test drives.
Unfortunately, I don't know which ones they could be in the case of PD.  Gruß Ulf
Translated on 16-10-2026, 10:13.
Profile PM Garage |
Trecker Treiber Guest
22-10-2003, 23:28 Subject: TDI Engine Jerks at 2150-2200 RPM |
I had a similar issue. VAG couldn't find any error codes in the system. After a long search and a lot of frustration, I found a damaged air hose after the turbo. Everything has been fine ever since.
Translated on 16-10-2026, 10:14.
Heiner Guest
22-10-2003, 23:43 Subject: TDI Engine Jerks at 2150-2200 RPM |
'... I've had a similar problem before, but I'm not sure where or how to start looking. I've noticed that the car makes a hissing sound quite often. But I'm not sure if that's just normal operating noise or something else?'
Where can I get VAGcomm from?
Translated on 16-10-2026, 10:15.
WarLord Guest
23-10-2003, 9:52 Subject: TDI Engine Jerks at 2150-2200 RPM |
If the car is frequently making whistling noises, check the charge air cooler system (from the turbocharger to the intercooler and from the intercooler to the intake manifold) for oil leaks.
Best regards, WarLord.
