Diesel Auxiliary Heater Upgrade to Standby Heater for 2.5 TDI
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
durnesss
Post24-10-2003, 7:47    Subject: Diesel Auxiliary Heater Upgrade to Standby Heater for 2.5 TDI Quote
I once read somewhere that the factory-installed diesel heater
for the 2.5TDI (here A6 AKN), it can be extended to function as a stand-heaters.
(yes, I know the search function here, but I can't find anything useful)
Who knows about that??
Thank you, Thomas.
Post24-10-2003, 8:11    Subject: Diesel Auxiliary Heater Upgrade to Standby Heater for 2.5 TDI Quote
http://home.arcor.de/naegele.andreas/htm/standhz.htm
I hope this helps you. But it's a Sharan.
christians
Post24-10-2003, 9:21    Subject: Diesel Auxiliary Heater Upgrade to Standby Heater for 2.5 TDI Quote
In some "Good Journey" booklet, there was also a guide.
Gruß Christian
Gremlin
Post24-10-2003, 13:57    Subject: Diesel Auxiliary Heater Upgrade to Standby Heater for 2.5 TDI Quote
www.webasto.de
www.eberspaecher.de (http://www.eberspaecher.de/de/heiz/tech/turbo/funkt/funkt.htm)
-> both have very competent hotlines and email service...
See you, Gremlin
Sebs
Post24-10-2003, 21:04    Subject: Diesel Auxiliary Heater Upgrade to Standby Heater for 2.5 TDI Quote
The Audi 2.5 TDI does not have an auxiliary heater, but an electric heater in the cooling circuit.
Therefore, retrofitting is not possible!
durnesss
Post24-10-2003, 22:28    Subject: Diesel Auxiliary Heater Upgrade to Standby Heater for 2.5 TDI Quote
I haven't bought the car yet.
but according to the manual, it has a diesel heater as standard.
runs automatically below 5°C outdoor temperature
Regardless of water temperature
until then, Thomas
No new posts Standheizung in Passat 3BG einbauen Troubleshooting & Guides
No new posts VW T4 111kW AHY, auxiliary heater defective Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Einbau einer Standheizung D5WSC mit Easystart R+ Troubleshooting & Guides
No new posts GRA expansion on 1Z Diesel Engine Technology
No new posts 5-Gang Getriebe auf 6-Gang Getriebe erweitern beim G3 AHU Diesel Engine Technology
No new posts AGR EGT Sensor for Audi A6 2.5 TDI Diesel Engine Technology
No new posts Einspritzdüsen ausbauen beim V6 2.5TDI Diesel Engine Technology
