Klaus Lenger Guest
30-10-2003, 12:09 Subject: TDI Golf IV: Engine Misfire, 96 kW, 2002 |
During the warm-up phase, at around 70 degrees Celsius, the engine vibrates at idle, similar to what you'd experience with a...
Benziner bei dem ein Zündkabel durchschlägt. LEverything is okay with the VAG group.
Furthermore, I occasionally experience a loss of power. According to VAG, everything is fine.
Translated on 21-09-2026, 0:36.
Bertil Profi-Schrauber
30-10-2003, 12:39 Subject: TDI Golf IV: Engine Misfire, 96 kW, 2002 |
The search function is your friend...
/viewtopic.php?t=1402&highlight=jerky+96kw
/viewtopic.php?t=3941&highlight=jerking+96kw
Translated on 21-09-2026, 0:37.
