Crankshaft Bolts: Problem Also for 1.6TD Engines?
profcosta
Post01-11-2003, 15:39    Subject: Crankshaft Bolts: Problem Also for 1.6TD Engines? Quote
Hello everyone!
Does the problem of the pulley keyway wearing out due to insufficient bolt preload also occur in the 1.6 TDI engines, or is this a problem specific to the larger 1.9 TDI engines? I have a 1.6 TDI engine in my Golf 1, and could problems with that bolt arise due to the significant increase in power to approximately 110 hp?
Translated on 27-10-2026, 2:30.
haehnlein
Post01-11-2003, 21:20    Subject: Crankshaft Bolts: Problem Also for 1.6TD Engines? Quote
"This also occurs with the AAz (1.9 TD) engine. I personally haven't encountered any cases with the 1.6 engine (what do the experts say?). In your situation, I would recommend proactively replacing the screw if you drive aggressively."
____________
Kein Auto mehr!
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts PBox: Compatible with ASV, not just AFN? Diesel Engine Technology
No new posts Door squeaks on the Golf III and possibly other models Transmission, Chassis, Body & Interior
No new posts Is the 96 kW PD engine still experiencing issues in the M... Diesel Engine Technology
No new posts Vag-Com Adapter: Compatible with New Audi A3? Diesel Engine Technology
