Fuel Pump Failure: Check Fuel Shut-Off Valve
aleksmeer
Post07-12-2004, 17:06    Subject: Fuel Pump Failure: Check Fuel Shut-Off Valve Quote
Hello everyone!!!
I know it's impolite to ask a question in my first post, but my knowledge of motorcycles far outweighs my limited basic understanding of diesel engines.
For some time now, my 1.9 TDI (ALH) has been running poorly. Sometimes it has full power, and other times it doesn't. I initially thought it might be the mass airflow sensor, but it wasn't. Then I suspected the vacuum pump on the turbocharger, but that wasn't it either. Then, on Saturday, it completely stopped working and it only ran in limp mode. So, I just went to an Audi dealer and had the error memory read. And there it was, a new error code: 01237, 'mechanical fault.' The nice man explained to me that 'mechanical fault' means that a piece of the valve has most likely broken off and fallen into the pump, and that the pump now needs to be completely replaced. icon_sad.gif I find that statement to be quite general, and I also can't find anything in this forum that supports that theory.
What do you think, how likely is that?
Translated on 24-09-2026, 23:33.
promethaeus
Post07-12-2004, 17:34    Subject: Fuel Pump Failure: Check Fuel Shut-Off Valve Quote
Hi. I've never experienced that before. But I can imagine that if a solenoid valve breaks, the engine might not be able to be shut off. So, if it's still running... The other thing is, if it sometimes runs normally, where could the broken piece be hiding?
I don't know. How many kilometers has the engine been driven?
Translated on 24-09-2026, 23:34.
aleksmeer
Post07-12-2004, 17:48    Subject: Fuel Pump Failure: Check Fuel Shut-Off Valve Quote
The engine has now been used for a maximum of 15,000 km. It wasn't installed for a long time. I bought it 'as a spare' because I drive about 60,000 km per year. If a piece had broken off, it should somehow clog something in the pump, rather than just causing a mechanical valve failure that leads to the limp-home mode.
Translated on 24-09-2026, 23:35.
aleksmeer
Post08-12-2004, 15:19    Subject: Fuel Pump Failure: Check Fuel Shut-Off Valve Quote
It's all sorted out, but thank you anyway. Nothing was broken except the valve. The guys in the workshop just laughed and said, 'Show-off!!!'
Translated on 24-09-2026, 23:36.
No new posts Workshop action: Defective coolant pumps in T4 and LT models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
No new posts Diesel Damage: Faulty Electronics & Wiring On-Board Diagnostics (OBD)
No new posts Fuel Injector Issues: Low Performance Causes Diesel Engine Technology
No new posts Defective heated seat Transmission, Chassis, Body & Interior
No new posts Hydraulic Lifters: Problems & Solutions Diesel Engine Technology
