TDI Engine Problems: Intermittent Power Loss
tdi-seppl
Post17-02-2008, 12:18    Subject: TDI Engine Problems: Intermittent Power Loss Quote
Perhaps someone has encountered this problem before.
Occasionally, roughly once a week, my Audi TDI with 110 horsepower and the AFN engine...
No power, as if the turbo is missing.
After turning off the engine and then restarting it, the engine runs normally again.
There are no errors stored in the error memory.
I'm ruling out LMM (Large Language Model) because the error only occurs very rarely.
Could it be related to the magnetic valve for boost pressure limitation? I don't want to buy it right now without being completely sure. Has anyone else experienced this issue before?
Hi TDI-Sepp,
Baust Du Turbo an Diesel,läuft Diesel wie Wiesel
Translated on 31-08-2026, 20:31.
3 Phasen Biber
Karma: +2 / -1   Thank you, like it!
2001 Volkswagen Golf
Post17-02-2008, 12:31    Subject: TDI Engine Problems: Intermittent Power Loss Quote
As always: you can't give a general answer, so please log the MWB 3/8/11 if the error is currently occurring!
ehemals G4 ASZ, jetzt G4 ARL
Translated on 31-08-2026, 20:32.
mullemaus
Post17-02-2008, 16:38    Subject: TDI Engine Problems: Intermittent Power Loss Quote
no power, it's like the turbo is missing.
After turning off the engine and then starting it again, the engine runs normally again.
Immediately after that, read the memory. It's a sporadic error that is cleared after a certain number of startup cycles. icon_wink.gif Search the documentation related to 00575. icon_wink.gif Something like that will be in there. }
Translated on 31-08-2026, 20:33.
DocSnyder75
2003 Mazda Mazda 6
Post25-03-2008, 21:55    Subject: TDI Engine Problems: Intermittent Power Loss Quote
I had the same problem with my Mazda6.
Ultimately, the problem was with the boost pressure control valve. I took it apart, cleaned it, and replaced the seals. It's been running without any problems since then.
Also, since recently, the performance is slightly reduced when the engine is cold, but this disappears immediately after a few kilometers. I never noticed this before.
Mazda 6 MZR-CD 89kw
Translated on 31-08-2026, 20:34.
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2263 - Turbocharger/Compressor, System: No Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 4Motion keine Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A6 96 keine Leistung Diesel Engine Technology
No new posts A6 2.5 TDi 103 KW-keine Leistung Diesel Engine Technology
No new posts A3 TDI: No Power? Troubleshooting Guide. On-Board Diagnostics (OBD)
No new posts A6 4b 2,5 TDI keine Leistung On-Board Diagnostics (OBD)
