How do you loosen the hinge screws on the A-pillar?
golf3schrauber
Post23-11-2003, 14:35    Subject: How do you loosen the hinge screws on the A-pillar? Quote
The passenger door on my Golf 3 is slightly misaligned with the body. To adjust it, you need to loosen the screws on the A-pillar and then align the door properly.
Is there a way to loosen the screws without using the VW 3320 tool?
Does anyone know approximately how much such a tool costs?
Gruss Oliver.
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 17-07-2026, 2:48.
Golfmann
Post23-11-2003, 17:15    Subject: How do you loosen the hinge screws on the A-pillar? Quote
I bought a Torx bit at the hardware store and welded it to an old open-end wrench. It works great.
Translated on 17-07-2026, 2:49.
golf3schrauber
Post25-11-2003, 12:57    Subject: How do you loosen the hinge screws on the A-pillar? Quote
I've tried that before too.
I got a double ring wrench that's curved like a banana and had a Torx bit welded into it.
The design allows easy access to the screws, but it's impossible to loosen them. There's only one position where the bit engages with the screw. When you start loosening the screw, the bit no longer fits into the next engagement point.
Now it should be possible to turn the bit in the holder!
So, everything's not that great.
Gruss Oliver.
Julian
Post25-11-2003, 14:26    Subject: How do you loosen the hinge screws on the A-pillar? Quote
Also alles nicht so toll.
Well, I don't want to complain, but Hazet, for example, makes combination wrenches with a rotating head (similar to ratchets). Those things cost around 10-20€, and I would rather buy one of those than start welding and messing around.
The screws on the door hinges need to be tightened very securely; otherwise, the door will easily become misaligned if it accidentally hits the retaining strap. And that raises the question of whether you can achieve this with your 'tool.'
Translated on 17-07-2026, 2:51.
Golfmann
Post25-11-2003, 15:12    Subject: How do you loosen the hinge screws on the A-pillar? Quote
That's true. They are very tight and need to be very secure. Mine have been holding for 2 years now. I removed both doors when I was painting. But so far, nothing has shifted.
Translated on 17-07-2026, 2:52.
No new posts Audi A3 Cracking Noise B-Pillar (8L 1996-2001) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A4 8D, production date up to 10/1999, dents on t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8P: Floor Covering Detaching Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 100 C4: Water in A-Pillar - Fix It! Transmission, Chassis, Body & Interior
No new posts Golf 4 leaking at the A-pillar (4-door) Transmission, Chassis, Body & Interior
No new posts What is the purpose of an ABE (General Operating Permit) ... Transmission, Chassis, Body & Interior
No new posts Remove Stuck Alloy Wheels: Easy Guide & Tips Transmission, Chassis, Body & Interior
