Nm Gearbox: Specs, Types & Applications
wacken
Post27-12-2003, 19:58    Subject: Nm Gearbox: Specs, Types & Applications Quote
Hi, I have a question. What happens if you modify a gearbox that's designed for a load of, say, 300 Nm, to handle 400 Nm or more? Is the stress on the gearbox (and engine) greatest in the lower gears, since there's the most force there? In higher gears, the 'forward thrust' is reduced due to the gearing, right? Is the stress not as high in the highest gear on the highway, for example, or does it not make a difference?
Translated on 07-10-2026, 9:03.
WarLord
Post28-12-2003, 13:11    Subject: Nm Gearbox: Specs, Types & Applications Quote
The load on the gearbox remains the same, regardless of whether you're in first or sixth gear, because the engine always delivers the same torque. In sixth gear, only the part of the drivetrain behind the gearbox is less stressed.
Best regards, WarLord.
Translated on 07-10-2026, 9:04.
No new posts Document LT 28, Transmission Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Audi A2 to A6, Gearbox Area, Customer Goodwill Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission AFN: Oil Change, Gearbox. Diesel Engine Technology
No new posts Upgrade 5-speed to 6-speed gearbox VW G3 AHU Diesel Engine Technology
No new posts TDI with transmission from the TD? Diesel Engine Technology
No new posts Does the transmission fit the ALH? Diesel Engine Technology
