The door lock no longer works in the cold.
karlstein12
Post29-01-2004, 12:30    Subject: The door lock no longer works in the cold. Quote
I'm having a problem with my Passat 3B (year 2000) where the door locks no longer close at temperatures below -5°C. The driver's door is particularly affected. The cause is that the small locking lever, which holds the locking hook, becomes difficult to move and no longer engages. (You have to warm it up with a hairdryer, then it works again.)
I also had this problem with my 35i earlier, but there I could remove, clean, and lubricate the lock from the outside. However, this only worked for a few weeks.
My question:
How can this problem be permanently solved, especially with the 3B, where access to the lock is only possible with a lot of effort?
Kriechöl, Caramba "So far, nothing has worked."
(I haven't found anything about this topic in the forum)
Greetings,
Rupert Gschwendtner
christians
Post30-01-2004, 17:15    Subject: Re: Door lock doesn't close properly in cold weather Quote
karlstein12 wrote:
How can this problem be permanently solved, especially with the 3B, where it is only possible to reach the lock with a lot of effort?
Kriechöl, Caramba, etc. have not worked so far.
I've written a post about this.
The only solution is to expand, disassemble, and lubricate. If it's similar to what I experienced with my Audi, you'll already see why it's difficult to achieve much when the lock is already installed.
Gruß Christian
No new posts Doku Golf 1J, Window doesn't close Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Door Lock Malfunction: A6 4B Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D Sliding Door: Repair & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Error Message in Cold Weather - False Alarm? Diesel Engine Technology
No new posts AGR Not Closing: LMM Value Never Reaches Target Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf 4 - Central locking not working with key, windows cl... Transmission, Chassis, Body & Interior
No new posts Intake valve not closing long enough, causing engine shake! Diesel Engine Technology
