Climate Change: Where is the Vaporizer?
dokky
2013 Volkswagen Golf
Post14-11-2003, 18:30    Subject: Climate Change: Where is the Vaporizer? Quote
Hello everyone,
I hope you can help me. My parents own an Audi A4 Avant TDI with 90 horsepower (first registered in June 1996).
The air conditioner is now emitting unpleasant odors. My question: Where can I spray the air conditioner cleaner?
"I haven't had to do that with my Fiat Stilo JTD. With my previous Marea, I simply removed the pollen filter, inserted the hose as far as it would go, and then just poured the product in."
Thank you for your answers.
Translated on 01-10-2026, 15:12.
Marco
Post14-11-2003, 18:49    Subject: Climate Change: Where is the Vaporizer? Quote
Hi Dokky,
Okay, remove the pollen filter (it's located on the top left of the water tank), insert the hose, and you're ready to go!
Before that, make sure to set the ventilation to its maximum setting.
Translated on 01-10-2026, 15:13.
dokky
Post14-11-2003, 18:50    Subject: Climate Change: Where is the Vaporizer? Quote
Okay. Can a fan be connected to it? With the Marea (year 1997), you had to force the hose past the fan. The fan was located in the engine compartment. I'll try that out.
Thank you very much.
Marco
Post14-11-2003, 18:58    Subject: Climate Change: Where is the Vaporizer? Quote
But be careful, the hose shouldn't be inserted so far that it gets in the way of the fan.
Translated on 01-10-2026, 15:14.
Varianti
Post17-11-2003, 8:59    Subject: Climate Change: Where is the Vaporizer? Quote
It's usually better (and cleaner) to use the recirculation vent inside the car. You can hold the bottle upright there and don't need to remove anything.
Just turn it on and insert the hose into the opening of the valve.
dokky
Post05-12-2003, 17:04    Subject: Climate Change: Where is the Vaporizer? Quote
We did it in the engine compartment. It was a piece of cake.
Translated on 01-10-2026, 15:15.
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climate Evaporator Lines Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Temperature sensor, evaporator, Passat 3BG 4Motion, 2.8L Transmission, Chassis, Body & Interior
No new posts Find the target resistance of sensor g308 (on the atomizer) Electrical Systems, Vehicle Electronics, Multimedia
No new posts 1.9 TD Diava with Climate Control Transmission, Chassis, Body & Interior
