Fuel Injector Disassembly and Assembly
christians
Post15-12-2003, 22:34    Subject: Fuel Injector Disassembly and Assembly Quote
Instead of a new monitor, I will be receiving a set of new nozzles as replacement parts icon_sad.gif in the next few days. Of course, I would also like to take a look at the inside of the old nozzles.
The question is whether I can easily reassemble it so that I can give it to my parts guy with a clear conscience. I'm not talking about repairing or adjusting it, just assembling it in a way that doesn't interfere with any subsequent overhaul.
Gruß Christian
Translated on 26-09-2026, 14:49.
Jan03
2010 Volkswagen Polo
Post16-12-2003, 9:01    Subject: Fuel Injector Disassembly and Assembly Quote
Hello.
If you're worried that they won't accept the old ones if you've tinkered with them, I can reassure you. In my case, they didn't even look at them. It could have been a dead cat in the bag icon_lol.gif.
The technician at Bosch mentioned that everything inside the injectors is replaced, and only part of the housing is reused. So, it shouldn't matter what you adjust inside, and if not all the parts go back in, it probably won't matter either. The main thing is not to damage the housing.
Jan.
Translated on 26-09-2026, 14:50.
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Clutch Pressure Plate Installation Guide Diesel Engine Technology
No new posts AC Compressor Installation: No Refrigerant Needed? Transmission, Chassis, Body & Interior
No new posts Disassembling a PD AJM Turbo Diesel Engine Technology
No new posts Disassembling pressure relief valves? Diesel Engine Technology
