Temperature Sensor Errors: Short Circuit to Ground
Weini
Post28-12-2003, 20:39    Subject: Temperature Sensor Errors: Short Circuit to Ground Quote
A friend of mine is experiencing the following problem with his Audi 80 B4 TDI (1Z), manufactured in 1994:
The car has lost power and can only accelerate up to about 100 km/h. I've already done some troubleshooting and tested the needle lift valve (see a few threads below). The effect was that the car wouldn't start at all icon_sad.gif.
Now, a friend has cleared the error memory, and the engine at least starts again icon_smile.gif. However, there are still many error entries present:
Fuel temperature, intake manifold temperature, and coolant temperature to some freezing temperature, and short circuit to ground. Similarly, mass airflow sensor -> short circuit to ground icon_mad.gif.
I wasn't present during the memory reading and clearing process, so I can't provide more details, but has anyone else experienced all of these errors at the same time? It sounds a bit like a broken cable in a common ground line... Unfortunately, the mechanic is also at a loss. icon_twisted.gif
It could also be a faulty engine control unit (ECU). Is there a way to have this tested somewhere (e.g., at a Bosch service center?), or possibly repaired? I'm not really keen on the workshop replacing the ECU based on suspicion, as it's likely to be very expensive.
Thank you & best regards,
Stefan
Translated on 24-10-2026, 14:04.
diesel.gustav
Post28-12-2003, 23:14    Subject: ECU Diagnostics: When Standard Tools Fail Quote
Deleted upon request.
Translated on 24-10-2026, 14:06.
Weini
Post29-12-2003, 14:53    Subject: Trade Shows: Your Guide to Success Quote
First of all, thank you to 'diesel.gustav'!
I'll soon be equipping myself with a multimeter to start searching and measuring the wires. Two mechanics have already tried this (with a wiring diagram), and as far as I understand, they measured 5 volts on various sensors. So, the voltage supply from the control unit seems to be working. It seems that the common ground wire to pin 33 is the only remaining possible source of error icon_confused.gif.
I hope it's not a defect in the control unit itself. If there isn't a clearly visible cold solder joint, I'm pessimistic about what can be repaired icon_cry.gif.
If I come up with a solution, I will definitely post it.
Stefan
Translated on 24-10-2026, 14:07.
Post29-12-2003, 19:01    Subject: Temperature Sensor Errors: Short Circuit to Ground Quote
My 1Z also had that problem before.
A short circuit in a cable within the wiring harness caused a ground conductor rail in the STG (System Test Generator) to burn out – a pretty cool failure.
Translated on 24-10-2026, 14:08.
No new posts Error code 005399 / P1517 - Short circuit to ground Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Short circuit Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Terminal 58d - Short circuit to ground Electrical Systems, Vehicle Electronics, Multimedia
No new posts Intake air temperature sensor (G72) - Short circuit to gr... On-Board Diagnostics (OBD)
No new posts Error 00532 - Power supply / Short circuit after positive... Diesel Engine Technology
No new posts High-pressure generator (G65) 009 - Ground interruption/s... Transmission, Chassis, Body & Interior
