Tachometer Installation Audi B4 TDI: Possible?
Audi_B4_TDI
Post22-01-2004, 10:44    Subject: Tachometer Installation Audi B4 TDI: Possible? Quote
Hello everyone,
Can a tachometer be installed in an AUDI B4 TDI?
If so, how?
Thank you very much!
Translated on 06-10-2026, 12:24.
Wurstblinker
Post22-01-2004, 12:53    Subject: Tachometer Installation Audi B4 TDI: Possible? Quote
That's absolutely no problem.
'Of course, you'll need the original tachometer with its mounting bracket. Check eBay occasionally, or inquire at www.Au-tel.de. I once bought a tachometer without the bracket and had to buy it from Audi for 18€.'
Remove the speedometer and disassemble it as far as necessary to be able to remove the clock mechanism.
The four connections of the digital tachometer (DZM) still need to be connected to the circuit board. Also, the clock display on the DZM is not lit, so you need to make a connection for that as well.
It's not that bad if you have some technical skills, but you have to be very careful because some parts are very fragile.
It essentially explains itself as you take it apart.
Sausage blinkers.
Translated on 06-10-2026, 12:25.
No new posts Lupo Tachometer Problem: 6X1 MJ 2002 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Oil proliferation in the ASZ. Incorporate PDEs and images Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tachometer Installation: VW Passat 1.6TD 1992 Transmission, Chassis, Body & Interior
No new posts Add Custom POIs to NAVI-CD: How-to Guide Diesel Engine Technology
No new posts Install VW Golf 3 TDI 1.9L Engine Diesel Engine Technology
No new posts Can you adjust the boost pressure with VAG-COM on an Audi... Diesel Engine Technology
