Vibrating When Light Is On: Troubleshooting Guide
WarLord
Post06-02-2004, 22:41    Subject: Vibrating When Light Is On: Troubleshooting Guide Quote
When I turn on the lights, it starts vibrating terribly (even the exhaust system starts vibrating). The engine is a 1Z in a Passat 35i. Could this be the infamous tensioner pulley for the ribbed belt?
Best regards, WarLord.
Translated on 08-10-2026, 17:51.
x world one
Post07-02-2004, 0:52    Subject: Vibrating When Light Is On: Troubleshooting Guide Quote
I've been experiencing the same issue recently. The timing belt and serpentine belt were replaced 4 weeks ago. I suspect it's the tensioner pulley.
Spritmonitor
Martin R
Post07-02-2004, 15:12    Subject: Vibrating When Light Is On: Troubleshooting Guide Quote
What happens if you turn on the rear window defroster (which has roughly the same power consumption) instead of the headlights?
Translated on 08-10-2026, 17:52.
x world one
Post07-02-2004, 16:05    Subject: Vibrating When Light Is On: Troubleshooting Guide Quote
Okay, and one more thing: In my case, for example, if I increase the idle speed to about 1000 RPM, the fuel consumption drops significantly.
Spritmonitor
WarLord
Post08-02-2004, 21:28    Subject: Vibrating When Light Is On: Troubleshooting Guide Quote
It's the same for me.
@Martin R
I'll try that out.
Translated on 08-10-2026, 17:53.
mersente
Post08-02-2004, 22:13    Subject: Vibrating When Light Is On: Troubleshooting Guide Quote
Hello, Does the alternator have a freewheel mechanism in the pulley? If not, please install one. icon_smile.gif
WarLord
Post08-02-2004, 23:46    Subject: Vibrating When Light Is On: Troubleshooting Guide Quote
'How can I identify it? How do I replace it? What's different about it? What advantages does it offer?'
mersente
Post08-02-2004, 23:57    Subject: Vibrating When Light Is On: Troubleshooting Guide Quote
Hello, you can identify the freewheel by the fact that the pulley can rotate freely in one direction without the alternator shaft rotating with it.
Sometimes, the 'friendly' free-flow exhaust system is not available for all engine codes, but other models may also fit.
First, remove the belt and rotate all pulleys and rollers to identify and limit any potential damage.
Based on my experience, this problem can occur after approximately 100,000-120,000 kilometers, even though there was no noticeable issue beforehand. icon_smile.gif
Translated on 08-10-2026, 17:54.
Post09-02-2004, 10:19    Subject: Vibrating When Light Is On: Troubleshooting Guide Quote
To the best of my knowledge, the 1Z models (at least the older ones) do not have a free-running feature.
He only came with the AFN.
The retrofit costs approximately 90 euros.
I've left it alone so far, but I've also thought about it.
Translated on 08-10-2026, 17:55.
No new posts Acoustic Noise Analysis: Identifying and Locating Sources... General Tips
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf4: Turn signals flickering, wipers too slow, lights t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AAT Vibration: Causes and Solutions Diesel Engine Technology
No new posts Engine Vibration at Idle: Causes & Fixes Diesel Engine Technology
No new posts Ruckeln-Vibrieren-Hoppeln, PD TDI bei 1.600 bis 2.000 rpm Diesel Engine Technology
No new posts Jerking/Vibration at 1800 RPM (ARL TDI) Diesel Engine Technology
