Manual Lumbar Support Adjustment: How To?
Post06-02-2004, 23:13    Subject: Manual Lumbar Support Adjustment: How To? Quote
If you manually move the actuation lever of the EGR valve on a PD TDI (ASZ) engine, is it normal to hear a hissing sound coming from the vicinity of the turbocharger pressure control valve?
The reason I'm mentioning this is because I suspect there might be a leak in that area, and I wanted to give the workshop a heads-up.
Translated on 09-10-2026, 5:43.
Karma: +807 / -0   Thank you, like it!
Post06-02-2004, 23:23    Subject: Manual Lumbar Support Adjustment: How To? Quote
Why don't you try using a vacuum pump to draw the liquid from the cans?
You can easily convert a bicycle pump into a vacuum pump by turning the piston inside.
Post07-02-2004, 11:29    Subject: Manual Lumbar Support Adjustment: Questions & Answers Quote
Roger wrote:
If you manually move the actuation lever of the EGR valve on a PD TDI (ASZ) engine, is it normal to hear a hissing sound coming from approximately the area of the turbocharger boost control valve?
Hi Roger,
"Control lever for the EGR valve on PD TDI engines (ASZ)?"
Although I am only 99% sure, I believe that the ASZ does not have any externally accessible AGR levers.
What you probably mean is the rod for the shut-off valve.
If you move them while the engine is running, you'll cut off the air supply to the engine, and you'll start to hear a hissing sound in the gap in the intake manifold - just like with a carburetor at idle.
If you can hear a hissing sound (like with an open carburetor), there's likely a leak somewhere between the spark plug and the shut-off valve, allowing air to be drawn in.
However, this hole would have to be surrounded by a pool of oil, because under load, the turbocharger's boost pressure would force oil mist out of the crankcase seal in that area.
Translated on 09-10-2026, 5:45.
Post07-02-2004, 12:17    Subject: Manual Lumbar Support Adjustment: How To? Quote
@ulfViewing profile: ulf:
I meant with the engine idling. I did a little searching yesterday because it seems like the car isn't building boost properly anymore. The "bump" around 2,000 RPM has decreased, and the torque curve seems to be more like a naturally aspirated engine. But it seems like there's been no change at higher RPMs.
I know that I should really do a diagnostic run now, but without a laptop, that won't be possible. When will VAG-Com finally be available for the Palm icon_cool.gif?
Well, I'm still under warranty. Those guys in the workshop should do something for their money. The first service is also due soon.
Thank you both!
Translated on 09-10-2026, 5:47.
WarLord
Post08-02-2004, 20:21    Subject: Manual Lumbar Support Adjustment: How To? Quote
Hmm, you want to test the AGR valve, or something? What do you mean by 'first service'? Is the car still under warranty?
Best regards, WarLord.
Translated on 09-10-2026, 5:48.
Post08-02-2004, 22:49    Subject: Manual Lumbar Support Adjustment: How To? Quote
@Warlord:
No, my primary concern was the airtightness of the vacuum hoses around the EGR valve, VTG (variable geometry turbocharger), BKV (boost control valve), etc. I'm ruling out a faulty EGR valve for now, as it produces very little smoke. Almost too little, I think.
The warranty is still valid, and there are 2,700 km remaining until the first service (currently, the total mileage is 25,600 km).
Translated on 09-10-2026, 5:49.
No new posts Hydraulic Jack: Manual Operation & Use Diesel Engine Technology
No new posts Exhaust Smoke: Diagnose Engine Damage? Diesel Engine Technology
No new posts Brake Light Stays On: Causes & Fixes Diesel Engine Technology
No new posts Second (Hand) Gas Pedal Installation for TDI "DIY Project" On-Board Diagnostics (OBD)
