GRA Spare Parts Number for the Passat 35i TDI?
Go to page: 1, 2  Next
WarLord
Post16-02-2004, 21:40    Subject: GRA Spare Parts Number for the Passat 35i TDI? Quote
Can someone please find this for me?
Best regards, WarLord
Post16-02-2004, 22:15    Subject: GRA Spare Parts Number for the Passat 35i TDI? Quote
35i or 3A (also sometimes also referred to as 35i)
So, was ist das Baujahr - Ist der 3A Satz vielleicht gleich dem Golf 3 Satz?
D. Kurz
Post17-02-2004, 10:18    Subject: GRA Spare Parts Number for the Passat 35i TDI? Quote
Hello!
The steering wheel switches from the 35i / 3A are, in my opinion, the same as those from the Golf III. But, what's the point? My GRA cost 7.50 euros in the electronics store... icon_smile.gif
Greetings,
Dominique
DocSnydor
Post17-02-2004, 10:57    Subject: GRA Spare Parts Number for the Passat 35i TDI? Quote
'Switch for turn signals, high beam, parking light and horn for vehicles with cruise control system':
1HO 953 513 D
Post17-02-2004, 11:45    Subject: GRA Spare Parts Number for the Passat 35i TDI? Quote
@ D.Kurz
Not quite !!
I learned how to deal with these types of people:
35i 88-92
3A 92-97
And the 35i definitely did NOT have the G3 levers, but the G2 facelift levers!!!
I drove a 90s Passat.
D. Kurz
Post17-02-2004, 12:52    Subject: GRA Spare Parts Number for the Passat 35i TDI? Quote
@Dieselmartin...
Auch der 3A wird noch als 35i bezeichnet. Ich nenne meinen Eicher auch beim freundlichen an der Ersatzteiltheke 35i, und zusammen mit dem Baujahr hat der bisher jedes Teil gefunden.
Up to 1992, they also had equal parts with a Golf... however, with the Golf II (in order to accurately count peas! icon_twisted.gif )
Greetings,
Dominique
Post17-02-2004, 13:22    Subject: GRA Spare Parts Number for the Passat 35i TDI? Quote
I don't think it's an overreaction, because the G3 Tempomat lever will definitely not fit optically, and probably not technically, into a car from before 1992.
I'm not sure what "wie" refers to, so I've written "my version" instead, so that everyone knows what I mean.
It wasn't about clarifying the different types of levers, but rather finding a suitable GRA lever.
And since a 1H0 lever is also a G3 lever, it is likely only for the Passat AB 92.
Post17-02-2004, 13:30    Subject: GRA Spare Parts Number for the Passat 35i TDI? Quote
Still something @ DOC
This is just the lever - there's a whole set for the G3.
Number ahb ich zu hause.
If Warlord makes a comment about the type of Passat he has, I'll start looking...
WarLord
Post17-02-2004, 21:43    Subject: GRA Spare Parts Number for the Passat 35i TDI? Quote
Should I get a TDI or not? *g* The Passat 35i didn't have a TDI, but the 3A was the first Passat to have a TDI. So, the Golf lever should probably fit (and if the wiring harness comes with it and the price is similar). On the levers, the part number will not be printed anyway.
Post17-02-2004, 22:03    Subject: GRA Spare Parts Number for the Passat 35i TDI? Quote
@ lord
Hm, actually, that's also true - I had forgotten that the TDI was only introduced in the 3A, because the VR6 was already available in the 35i - which I didn't know before...
Okay, then I'll start looking for...
http://people.freenet.de/golf-schrauber/gra.jpg
Please see, this is a scan of an invoice.
WarLord
Post17-02-2004, 22:43    Subject: GRA Spare Parts Number for the Passat 35i TDI? Quote
For what are the 'Satz Leitung', the 'Stossverbindung' and the 'Abdichtungen' used?
Post17-02-2004, 23:08    Subject: GRA Spare Parts Number for the Passat 35i TDI? Quote
I received the scan from another forum.
I did the GRA installation myself during the purchase and had it installed.
I think that the sentence doesn't really contain ALL the parts, the parts seem to be related to electrical equipment.
DocSnydor
Post18-02-2004, 8:32    Subject: GRA Spare Parts Number for the Passat 35i TDI? Quote
I don't know if the lever alone is much cheaper, but it's perfectly sufficient. I actually built it myself.
By the way, my vehicle registration also states 35i. 3A clearly says 'no nonsense'. icon_wink.gif
Post18-02-2004, 8:54    Subject: GRA Spare Parts Number for the Passat 35i TDI? Quote
The... are among us:
http://www.dieselschrauber.de/Getriebe_Main.html
And Google finds even more.
But that doesn't matter - I have a Golf and a GRA, and I've said everything I know about it here.
Hello
D. Kurz
Post18-02-2004, 10:34    Subject: GRA Spare Parts Number for the Passat 35i TDI? Quote
@Doc
Exactly my opinion! icon_lol.gif 3A... how stupid, the newer ones are so much better if you don't work for VW, until then it was perfectly clear with the Passat, and of course after the old system (Type 17, Type 53, 53 b, ...).
@Warlord
If the person you're talking to doesn't randomly mention that the Golf III speaker connection also works with the 35i, then I can tell you from my own experience that the small, flat speaker connectors will fit into the pins on the connector behind your fuse box. You might also need to add a small piece of electrical tape to secure them. And according to diagram 4, running 4 wires to it is definitely possible. Unlock the system in the control unit, of course, and then cruise...
Greetings,
Dominique
WarLord
Post19-02-2004, 20:56    Subject: GRA Spare Parts Number for the Passat 35i TDI? Quote
That's in case I only get the lever and not the hose set, right?
No new posts Explanation of the VAG part number Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB ASV: STG Part Numbers & Identification Diesel Engine Technology
No new posts Pressure Relief Valve Part Numbers Diesel Engine Technology
No new posts Girling part number 60 Transmission, Chassis, Body & Interior
No new posts Part Number Driveshaft Transmission, Chassis, Body & Interior
