A4 8E Smoke: Causes, Repair & Prevention
Leo Duursma
Post04-03-2004, 15:45    Subject: A4 8E Smoke: Causes, Repair & Prevention Quote
My A4 8E 2.5 TDI 132 kW Quattro exhibits a significant amount of smoke below 2,000 RPM, even under less than full load. The engine has an *** chip installed.
Could this possibly be related to a faulty AGR valve?
How can I possibly block the AGR (Abgasrückführung) system?
I also doubt whether a fuel consumption of around 8.0 liters per 100 kilometers is acceptable, even with a moderate driving style.
Perhaps someone here can help me.
Leo.
Translated on 13-10-2026, 12:14.
Post04-03-2004, 17:30    Subject: A4 8E Smoke: Causes, Repair & Prevention Quote
Could this perhaps be related to a faulty AGR valve?
Yes!
Regarding your remaining questions: please use the search function!
Regarding the keyword "metal gasket" and the technical article about the AGR valve, I cannot tell you whether the engine control unit detects and sanctions any manipulation (i.e., whether repairing the AGR valve is more advantageous).
To check if the EGR valve is actually the cause of your black smoke, you can temporarily disable it for a short period.
Translated on 13-10-2026, 12:15.
Leo Duursma
Post04-03-2004, 22:22    Subject: A4 8E Smoke: Causes, Repair & Prevention Quote
Thank you, Rainer.
I will first try to set the AGR style.
Leo.
Translated on 13-10-2026, 12:16.
No new posts Smoke Detection in Fire Alarm Systems Diesel Engine Technology
No new posts Engine Failure: Smoke and Performance Issues Diesel Engine Technology
No new posts A6 C4 2.5L AEL: Poor Performance & Smoke On-Board Diagnostics (OBD)
No new posts Engine Smoke: Troubleshooting High RPM Startup Diesel Engine Technology
