T4 Turbocharger: Performance & Upgrade
mopu
Post29-02-2004, 19:44    Subject: T4 Turbocharger: Performance & Upgrade Quote
Hello.
Another beginner's question.
Is it possible to increase the performance of a 90 or 110 HP TDI engine by using a turbocharger from a T4 bus with 150 HP?
'Thank you.'
Translated on 24-09-2026, 23:51.
mersente
Post29-02-2004, 20:58    Subject: T4 Turbocharger: Performance & Upgrade Quote
Hello, in principle, that's possible, but you'll also need to find someone who can adjust the engine control unit's mapping to match the other turbocharger.
Translated on 24-09-2026, 23:52.
Thomas
Post02-03-2004, 19:25    Subject: T4 Turbocharger: Performance & Upgrade Quote
Back then, VW Motorsport fitted the R-TDI engine with a VNT20 turbocharger.
It's essentially the same as a GT2052V turbocharger from a 180PS V6 TDI engine.
The R5 TDI engine with the engine codes AXG and AHY also uses a GT20 turbocharger, but they differ in aspects such as the compressor housing.
In principle, it is possible to fit this turbocharger to a 4-cylinder TDI engine with a suitable manifold, but I doubt it will spool up fully much below 3000 RPM. You will experience a relatively large turbo lag. For a racing TDI, which has an idle speed of 2000 RPM and the running characteristics of a tractor, this is somewhat acceptable.
However, all of this naturally depends on the amount of exhaust gas available.
If you can produce enough exhaust gases even at low engine speeds, it can also exhibit a reasonably responsive behavior.
See you later.
Greetings.
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 24-09-2026, 23:53.
No new posts VTG Loader: Operating principle and settings Technical Articles
No new posts Garrett VTG-L turbocharger Diesel Engine Technology
No new posts Control unit and charger? Diesel Engine Technology
No new posts AMF Engine Loaders: Part Numbers & Info Diesel Engine Technology
No new posts various VNT 15 loaders (AFN u. ASV/ALH)? Diesel Engine Technology
