Oil Pressure High After Seal Replacement?
Boro
Post08-03-2004, 19:46    Subject: Oil Pressure High After Seal Replacement? Quote
Hab heute meinem AFN ne` neue Ventildeckeldichtung sowie neue Dichtungen für die Ventildeckelschrauben und die Kurbelgehäuseentlüftung spendiert. NaI'm currently...
'There was quite a bit of oil that came out of it at 191,000 km! So, I removed the valve cover and cleaned everything thoroughly. The inside looked great, with no oil sludge and no visible signs of wear on the camshaft and lifters. Then I installed the new gaskets!'
To my surprise, I then noticed that the oil pressure at idle is now exactly 2 bar! The oil temperature is 84°C. Before, it was always around 1.4-1.6 bar! Since I have an oil pressure gauge, I can easily read these values at any time.
Could a slight leak in the valve cover cause the pressure to drop that much?
While it's still within the acceptable range, it's definitely a noticeable difference!
What do you think?
Translated on 11-10-2026, 15:46.
Karma: +807 / -0   Thank you, like it!
Post08-03-2004, 19:56    Subject: Oil Pressure High After Seal Replacement? Quote
Hi, your new oil likely has a higher viscosity at the measured oil temperature...
Translated on 11-10-2026, 15:47.
Post08-03-2004, 20:55    Subject: Oil Pressure High After Seal Replacement? Quote
It's definitely not the poetry! Also, check the oil (or maybe you left a rag in there while cleaning......just kidding!!!) icon_lol.gif
Boro
Post09-03-2004, 7:48    Subject: Oil Pressure High After Seal Replacement? Quote
'Umm, I only changed the seals, not the oil! And all the rags are still here! Hmm, I'll keep an eye on it.'
Translated on 11-10-2026, 15:48.
Post09-03-2004, 8:11    Subject: Oil Pressure High After Seal Replacement? Quote
Oops, sorry, I also thought the oil would be new! That's why it's quite strange, because the valve cover area isn't under full oil pressure!!!!
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Pressure After Starting? Diesel Engine Technology
No new posts No oil pressure after oil change on 1.9 TDI AVF engine Diesel Engine Technology
No new posts Consumption display approximately 30% higher than measure... On-Board Diagnostics (OBD)
No new posts Tire Wear on Inner Edge: Causes & Solutions Transmission, Chassis, Body & Interior
