AEL Tuning: Performance Optimization
martin119
Post08-03-2004, 15:01    Subject: AEL Tuning: Performance Optimization Quote
Unfortunately, I haven't found much using the search function, so I'm asking again:
Does anyone have a chip, power box, or similar device installed in their AEL vehicle?
What positive and negative experiences?
How much does it cost?
My car now has 240,000 km on the odometer, but the turbo and injectors are new, and there's no oil consumption. It should be okay, or would it be better to replace the timing belt and head gasket?
Martin.
Translated on 02-10-2026, 10:08.
christians
Post08-03-2004, 20:21    Subject: AEL Tuning: Performance Optimization Quote
Is it running better now with the new nozzles?
Gruß Christian
Translated on 02-10-2026, 10:09.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post08-03-2004, 20:48    Subject: AEL Tuning: Performance Optimization Quote
Still need to replace the timing belt and head gasket?
The timing belt doesn't matter if the engine has 30 more horsepower because the engine doesn't rev higher, and therefore it's not put under any more stress than it would be in its standard configuration.
Just leave it in until it's due.
"I don't think you should worry too much about the head gasket; usually, cracks develop in the head itself, for example, due to poor casting. But the injectors are new, so that's good."
"Just put the chip in and drive like before. If something breaks, you can always replace it later."
Is the AEL the 150hp V6 engine?
B.Eng (FH) u. KFZ Meister
Marco
Post08-03-2004, 21:59    Subject: AEL Tuning: Performance Optimization Quote
Hello Steffarn,
No, the AEL is a 5-cylinder engine.
Translated on 02-10-2026, 10:11.
No new posts 10Cent Tuning Technical Articles
No new posts Tuning: Intake & Intercooler - Optimization Guide Technical Articles
No new posts Fuel injector replacement: Tuning without electronic modi... Technical Articles
No new posts Good tuning, bad tuning? Diesel Engine Technology
No new posts TDI Tuning: AFN Engine Optimization Diesel Engine Technology
No new posts PD Tuning Diesel Engine Technology
No new posts PD 150 Tuning: Performance & Optimization Diesel Engine Technology
