Ford Focus TDDI: AGR Valve Problems & Whistling?
DieseL77
Post05-03-2004, 19:32    Subject: Ford Focus TDDI: AGR Valve Problems & Whistling? Quote
Hey, I picked up my 90hp TDDI Focus from the dealer today. My AGR valve was broken and it was replaced today, along with the intake manifold. So far, so good, the performance is normal, everything seems fine. However, I suddenly hear a 'turbo whistling' sound? I couldn't find any cracks or anything like that, and the hoses are new and seem to be sealed properly. Could it be coming from the intake manifold/AGR valve?
Translated on 18-09-2026, 14:05.
mersente
Post05-03-2004, 21:05    Subject: Ford Focus TDDI: AGR Valve Problems & Whistling? Quote
Hello, what kind of defect did you have? So, if the EGR valve was always open, you would have experienced a lack of power, which would have prevented your turbocharger from working properly. Now, as you say, the engine has power again. Does your turbocharger occasionally whistle, or is it excessively loud?
A whistling sound doesn't necessarily indicate a defect.
Translated on 18-09-2026, 14:06.
DieseL77
Post06-03-2004, 7:01    Subject: Ford Focus TDDI: AGR Valve Problems & Whistling? Quote
The turbo whistles constantly, not excessively loud. The AGR seemed to be faulty, but I couldn't detect a significant loss of power. Occasionally, it lacked a bit of power. We only discovered the AGR defect somewhat by chance when we wanted to install the latest software version. Since there is still a warranty, it was replaced immediately icon_smile.gif.
Translated on 18-09-2026, 14:07.
DieseL77
Post06-03-2004, 14:51    Subject: Ford Focus TDDI: AGR Valve Problems & Whistling? Quote
The funny thing is, all the people I know and ask (even at the club) don't have any turbo whistle sounds with their Ford diesel engines. icon_sad.gif
Post06-03-2004, 19:11    Subject: Ford Focus TDDI: AGR Valve Problems & Whistling? Quote
"A friend of mine also has a TDDI (I think it's the 90 HP 1.8L engine, right?). I haven't noticed any whistling sounds from his either, probably because the engine has a rather rough running sound. However, I wouldn't worry too much unless the noise sounds concerning and the car doesn't have any issues with acceleration (…you have a warranty, so go back to Ford and tell them it's making strange noises. That way, you'll have it documented in case something goes wrong, and everything will be okay!)."
Translated on 18-09-2026, 14:08.
DieseL77
Post06-03-2004, 19:33    Subject: Ford Focus TDDI: AGR Valve Problems & Whistling? Quote
Yes, the warranty is more than sufficient (4 years, and only 1 year has passed so far icon_smile.gif). I will go there again on Monday to clarify this. The performance is excellent, and with the new EGR, you can really feel the turbo now icon_smile.gif.
Translated on 18-09-2026, 14:09.
DieseL77
Post09-03-2004, 21:01    Subject: Ford Focus TDDI: AGR Valve Problems & Whistling? Quote
Okay, so, I went to the friendly technician again, and the cause of the whole problem was an error during the installation of the latest software. I reinstalled it, and the whistling is gone, the airflow is there icon_smile.gif. You wouldn't believe what all can cause problems icon_biggrin.gif.
No new posts Ford Focus 1.6 TDCi - Error code P1181 General Tips
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Ford Fiesta Temperature Sensor: Problems & Fixes General Tips
No new posts Focus TDDI 90hp problem / P0235 boost pressure sensor &am... On-Board Diagnostics (OBD)
No new posts Ford TDDI: Rough Idle & Troubleshooting Diesel Engine Technology
No new posts Ford Focus 1.8 TD timing belt replacement Diesel Engine Technology
No new posts 1.6 PSA Diesel in the 2005 Ford Focus Diesel Engine Technology
