Outdoor Temperature Sensor: Best Placement Location
hollari
Post05-10-2006, 13:03    Subject: Outdoor Temperature Sensor: Best Placement Location Quote
I would also like to have a reasonably accurate outside temperature reading while driving.
Advertisement, and now I'm asking you where the sensor should be mounted.
The engine compartment is probably not the ideal location, as it gets hot, especially in diesel engines.
I was thinking it's most likely located near the air intake (possibly in the air filter), on the engine.
(or turbocharger) should be supplied with as much cool air as possible, or am I wrong?
Did I forget something important?
How is the water tank?
Perhaps someone knows where this type of component is typically mounted in cars that have it as standard equipment.
VW Vento TDI, manufactured in 1995, 66 kW.
Translated on 14-10-2026, 2:59.
Jochen_145
Post05-10-2006, 13:21    Subject: Outdoor Temperature Sensor: Best Placement Location Quote
It depends on the purpose for which the temperature is being measured.
There are various outside temperature sensors in the car, each controlled by different control units.
Sure, please provide the text you would like me to translate from German to English.
Combination instrument: located either below the front bumper or in front of the radiator -> purpose: to draw in outside air and to provide a warning about icy road conditions.
Climate Control Unit: Typically located in the water tank and combined with the air quality sensor -> Purpose: To measure the air being drawn in for the interior space.
In the engine compartment, you all know the sensors yourselves icon_smile.gif.
Best regards, Jochen.
Translated on 14-10-2026, 3:01.
hollari
Post05-10-2006, 14:12    Subject: Outdoor Temperature Sensor: Best Placement Location Quote
I'm going to install an outdoor temperature display.
It has a MAX-MIN function, which means it continues to operate even after the engine is turned off.
The cooler should not heat up the sensor.
To what extent does the hood actually release heat during driving, and how does this heat then dissipate?
is the water tank being sucked into the interior?
Translated on 14-10-2026, 3:02.
Jochen_145
Post05-10-2006, 15:21    Subject: Outdoor Temperature Sensor: Best Placement Location Quote
The hood dissipates the heat that builds up around the engine. However, this is not very effective due to the insulation mat underneath the hood. While driving, the hood is cooled by the airflow.
You will only noticeably feel the hood getting warm when you remove the insulation mat and then drive with a heavy load at low speeds. In this case, the air being drawn over the water tank by the air conditioning or ventilation system is already warming up.
However, this is relatively insignificant for our latitudes.
When you're in Spain with a running or hot engine exposed to the sun, the air conditioning system draws in air that has already been heated by the sun.
This is the reason why, when the climate control system is set to its maximum cooling mode, it switches to 'interior' mode at the beginning of the cooling process, even though the air inside the car is significantly warmer than the outside air.
I would place your sensor as far forward as possible, at the very bottom, and as far away from the radiator as possible, in the front-end. This area experiences the coldest temperatures in winter (ice warning). Radiation heat is negligible here. Seat also chose this location for the sensor in the Leon.
Translated on 14-10-2026, 3:04.
Avatar-Jan6K
Post05-10-2006, 16:45    Subject: Outdoor Temperature Sensor: Best Placement Location Quote
either on the front side of the bumper or on the bottom of the side mirrors (which is how Seat did it on the Ibiza).
Jan.
1Z5 CFHF / AHB H4D
Translated on 14-10-2026, 3:05.
No new posts P246E - Exhaust Gas Temperature Sensor (EGS) Bank 1 Sensor 4 General Tips
No new posts Intake Air Temp Sensor P0110: Causes & Fixes General Tips
No new posts P0341 - Camshaft Position Sensor (G40): Implausible Signal Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts How is the factory-installed AHK (trailer hitch) wired? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Wheel Alignment Today: New Tires Installed Transmission, Chassis, Body & Interior
No new posts Timing belt incorrectly installed?, even though the injec... Diesel Engine Technology
No new posts MAP Sensor for AKN Engine On-Board Diagnostics (OBD)
