Audi A3 speedometer and fuel gauge malfunction
voss
Post28-03-2004, 10:26    Subject: Audi A3 speedometer and fuel gauge malfunction Quote
Hello.
Can anyone help me?
Problem: The speedometer is not working, and the fuel gauge is malfunctioning. It seems to be affected by the movement of the fuel in the tank (showing too much fuel when accelerating and almost zero when braking).
It has already been checked.
Error memory in combination instrument panels? No error?
Engine fault memory? No error? The measurement block also only shows 0 km/h.
Error memory for automatic transmission? No signal from the G-38 speed sensor.
"What's deleted is gone forever? It's possible that someone here wanted to try something out and simply disconnected the device for a short time."
Cables in the engine compartment, checking for breaks and small rodents? No results found.
Car: Audi A3, year 1998, 1.8T engine (not a TDI), with a 4-speed automatic transmission.
I suspect the speed sensor is the issue, the one for the speedometer. But where is it located, and how can I best access it? Also, why is the fuel gauge behaving strangely?
Sure, here's the translation:
"Thank you in advance for any help."
Best regards to everyone.
Voss.
D.
Post28-03-2004, 10:55    Subject: Audi A3 speedometer and fuel gauge malfunction Quote
If I remember correctly from one of the recent posts, this must be due to the so-called 'comfort function.'
Try searching for it.
Best regards, D.
voss
Post28-03-2004, 12:36    Subject: Audi A3 speedometer and fuel gauge malfunction Quote
Hello D.
Sure, thanks for the quick reply.
but what do you mean by "must this be due to the so-called "comfort function"?"
Are you referring to something like the speedometer malfunctioning, or how the fuel gauge is behaving?
I couldn't find anything useful under the "comfort features" section.
Voss.
Martin R
Post02-04-2004, 19:02    Subject: Re: Audi A3 speedometer and fuel gauge malfunction Quote
Hello.
Perhaps the damping effect only starts to work above a certain speed.
And because of the faulty speedometer sensor, the instrument cluster doesn't receive the V signal.
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document MKB AKQ, defective timing belt tensioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking Assist Fault: Audi A6 (4B) Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Speedometer Malfunction: How to Replace It On-Board Diagnostics (OBD)
No new posts Skoda dashboard/instrument cluster faulty Transmission, Chassis, Body & Interior
No new posts VW Golf 4: Replace Analog Speedometer with FIS Display Transmission, Chassis, Body & Interior
No new posts Golf 3 Fuel Gauge Inaccurate - Troubleshooting Transmission, Chassis, Body & Interior
